1. Family Team's Avatar
    My phone is samsung galaxy note 5 model n920p its a sprint device but i unlocked it to use gsm sim cards and sim cards works only on stock rom when i tried on custom rom pie and copied all the libs files and ril files i always ended up with unknown baseband and in ril log files i get
    RILClient: Connect_RILD: Connecting failed. Connection refused(111)
    The custom rom i am using is android pie one ui its base is note 8
    With help of the dev we made a working kernel with all the ril requirements but the problem now is rom side any help please and thanks in advance
    11-14-2019 05:15 AM
  2. mustang7757's Avatar
    Hi, welcome !
    That's something you have to see if the developer of that ROM can fix , we can help with troubleshoot on a stock firmware
    Family Team likes this.
    11-14-2019 09:36 AM
  3. B. Diddy's Avatar
    I moved this to the Note5 forum for more specific traffic.
    11-16-2019 10:25 PM
  4. Family Team's Avatar
    okay you said on stock firmware i flashed n920c stock firmware with my stock kernel and i got same results in log files as in custom roms its android 7.0
    11-22-2019 01:08 PM
  5. mustang7757's Avatar
    You said it work with stock ROM before ?
    11-22-2019 01:11 PM
  6. Family Team's Avatar
    sorry for late reply yes it worked on stock and it is still working
    what i did try is to install another model stock rom on my phone to figure out how ril works i did copy all required lib files and bin files and i couldn't make the sim to get detected or getting a baseband version in about phone
    my model is n920p android 7.0
    the rom i tried was n920c android 7.0
    flashed stock kernel so its a system side only
    12-08-2019 08:51 PM
  7. mustang7757's Avatar
    Hi, yeah on different Rom we can't help like I mentioned earlier you'll need to try talk to the developer of it or play with things until you figure it out .
    12-08-2019 08:57 PM
  1. Can i switch from Mobile Nation to Straight Talko i
    Last Post: 11-16-2019, 10:44 PM
  2. Moto G7 power. Can't set incoming Messages to sound/vibrate
    Last Post: 11-16-2019, 10:40 PM
  3. Where to put custom ringtones
    By ZR1Tom in forum Samsung Galaxy S10 & S10+
    Last Post: 11-16-2019, 06:20 PM
  4. Where to put custom ringtones
    By ZR1Tom in forum Ask a Question
    Last Post: 11-13-2019, 08:10 PM
