1. jisddwqs's Avatar
    Not all usb-c cables are created the same. Benson Leung at Google has reviewed numerous cables, and there are quite a few non-compliant cables. These cables can result in weird, or even dangerous behavior.
    Recommended USB Type-C Legacy Cables:https://www.amazon.com/gp/registry/w...cUvbUpU5296995 (Benson's Amazon Profile)
    You guys can also follow his Google+: https://plus.google.com/+BensonLeung/posts
    The USB C Adapter I bought from Tronsmart:https://www.amazon.com/dp/B018S827GU...cUvbUpU5296995
    The C TO A Cable I bought from iOrange:https://www.amazon.com/dp/B010VFFU1W...cUvbUpU5296995
    If you don't want to risk anything make sure you always use the compliant cables/adapters
    08-03-2016 02:54 AM
  2. Kirk Maluo's Avatar
    Or to be even safer, buy an OEM cable.
    08-03-2016 05:19 AM
  3. Almeuit's Avatar
    If Benson says one is safe then it's safe. He knows his stuff .
    08-03-2016 07:30 AM
  4. D13H4RD2L1V3's Avatar
    Any cable recommended by Benson should be fine.
    08-03-2016 09:30 AM
  5. Vandito's Avatar
    So where can I see a list of the non compliant cables
    08-03-2016 09:40 AM
  6. Gayle Lynn's Avatar
    I have Apple laptop that uses USB-C and I would feel safe with one recommended as supporting MacBook etc that relies on one. Anker 60W 5-port with USB-C
    08-03-2016 10:40 AM
  7. Kirk Maluo's Avatar
    Assuming Samsung is using a compliant cable on their non compliant port.
    08-03-2016 01:38 PM
  8. anon(27512)'s Avatar
    Does this phone have USB c fast charging?
    08-03-2016 02:48 PM
  9. Kirk Maluo's Avatar
    Technically USB C doesn't have true Quickcharge capability. Samsung and Qualcomm break from Spec and allow quickcharging.
    08-03-2016 05:26 PM
  10. aparker2005's Avatar
    So I got my extra cable from spigen today with a case. Which single or double car charger should I get?
    I can still plug my wife's iPhone 5s into the new car charger if we get a double right? This C stuff is all new to me.
    And I can use the new cable to plug into my hp laptop? Thanks ahead
    08-03-2016 05:39 PM
  11. ohbreeeezy's Avatar
    https://www.amazon.com/Charger-AiPow...cUvbUpU5298889
    https://www.amazon.com/Charger-Charg...cUvbUpU5298889
    or if you want to use your old micro usb cable
    https://www.amazon.com/Anker-Adapter...cUvbUpU5298889
    08-03-2016 05:48 PM
  12. aparker2005's Avatar
    And it's still safe to plug in to the computer with the new cable right? Thanks!
    08-03-2016 05:56 PM
  13. aparker2005's Avatar
    And will the first one charge my wife's iPhone? I'm guessing just the note 7 needs a c type and not the iPhone obviously?
    08-03-2016 05:59 PM
  14. ohbreeeezy's Avatar
    yea ofc
    08-03-2016 06:01 PM
  15. aparker2005's Avatar
    Just didn't want to get a usb-c charger for the car and she plug her regular iPhone cable into it and mess anything up. Looks like I'm behind on research lol
    08-03-2016 06:16 PM
  16. Kirk Maluo's Avatar
    There's a fast wireless car charger on Amazon that's pretty cool. Doesn't charge fast when the screen is on though. Saves wear on your usb port too.
    08-03-2016 07:05 PM
  17. brisk172's Avatar
    Hi, can someone tell me if this car charger will support Quick Charge? Or can recommend another device similar like this one that is small?
    https://www.amazon.com/gp/product/B01B2BMIMS/ref=ox_sc_act_title_2?ie=UTF8&psc=1&smid=A142BGUZC6UH73
    08-05-2016 07:50 AM
  18. dsignori's Avatar
    It does support quick charge 2.0 and 3.0. It quick charges my Note 5 quickly now (via fast-charge). I think there might still be some uncertainty with the Note 7 , USB C, and various chargers in relation to charging speeds though.
    08-05-2016 03:12 PM
  19. feihu989's Avatar
    08-06-2016 05:59 AM
  20. phone-a-holic's Avatar
    08-06-2016 03:27 PM
  21. Pippinsky's Avatar
    Hopefully Benson likes my choice of anker cables, they seem awesomely built
    08-14-2016 10:18 PM
  22. jisddwqs's Avatar
    Check here:https://www.amazon.com/gp/pdp/profil...cUvbUpU5347439 Some cables are not approved by benson. DO BUY THEM.
    08-19-2016 10:17 PM
  23. calicocat2010's Avatar
    What about this one? USB Type C Cable, CHOETECH 6Pack [1.6ft*1+3.3ft*4+6.6ft*1] Durable USB C to USB A (Type C to Type A) Cable for Galaxy Note 7, OnePlus 3, LG G5, HTC 10, Lumia 950, new MacBook and More
    Mine won't be delivered until August 29th is what the confirmation says.
    08-19-2016 10:31 PM
  24. rdimedic's Avatar
    Is there a list of approved wall chargers that anyone can link? I can't seem to find a list.
    08-20-2016 09:03 PM
  25. jisddwqs's Avatar
    You can buy QC 2.0 wall chargers or QC 3.0 wall charger. Just use a type c to a cable to charge your note 7 via A USB A port charger.
    08-21-2016 09:38 PM
  1. Samsung Note 7 violates the USB Type-C Spec?
    By jisddwqs in forum Samsung Galaxy Note 7
    Last Post: 08-03-2016, 05:39 PM
