09-06-2016 05:05 AM
62 123
tools
  1. Savoy's Avatar
    Ok so i haven't bought an sd card since my note 4. That has a 64 gig in it. I think it was a San disk i think class 10? So for my note 5 i couldn't use it which that phone is going to my wife. It's 64 gig and plenty of space for her.
    Anyway i want to order a 128 gig sd card for the note 7 which i just pre-ordered but i want to make sure i get the fastest one i can get. I'll be taking the fit2 as the pre order bonus so I'll buy this. 128 will be fine for me.
    Thanks.
    08-03-2016 06:21 PM
  2. SpookDroid's Avatar
    As long as it's at least a Class 10 (faster transfers are better, especially if you're thinking about doing 2K video) and from a reputable brand, you should be fine. The usual suspects are SanDisk, Samsung, etc.
    HOWEVER, Samsung and Samsung always work better together, so their line of SD Cards are probably your best bet.
    08-03-2016 06:25 PM
  3. anon(782252)'s Avatar
    I guess it depends on your budget but I have this one and pretty happy with it.
    https://www.amazon.com/Samsung-128GB...cUvbUpU5299060
    jackwins likes this.
    08-03-2016 06:26 PM
  4. Savoy's Avatar
    Thanks guys. I didn't realize 128's were still so expensive. I'll Hunt around on amazon a bit.
    08-03-2016 06:45 PM
  5. PlaybookFanatic's Avatar
    Why don't you just pre order and get the free 256?
    SpookDroid and mariievil like this.
    08-03-2016 06:54 PM
  6. anon(782252)'s Avatar
    The 128's are still pretty expensive if you want write speed in the 80+ range. The Samsung Evo line is pretty solid as well, much cheaper, but much slower write speed as well.
    08-03-2016 06:54 PM
  7. Savoy's Avatar
    I was planning on getting the fit2 as the pre order bonus.
    08-03-2016 06:56 PM
  8. PlaybookFanatic's Avatar
    I didn't think anyone was actually getting that, especially since the 256 is the top of the line that Sammie has at the moment (and saves them 250 bucks). But if you'll actually use the watch, then go for it. I have a fitbit, Gear S2 and a LG G Watch R. You forget to wear them often lol.
    G6400 likes this.
    08-03-2016 07:02 PM
  9. jackwins's Avatar
    https://www.amazon.com/Samsung-128GB...cUvbUpU5299144
    I have that one too. Got it when the S7 came out. Its dope.
    08-03-2016 07:02 PM
  10. Savoy's Avatar
    I just ordered the 128 pro samsung. I want the fast write speed. Appreciate the info guys.
    felloffthetruck likes this.
    08-03-2016 07:13 PM
  11. dpham00's Avatar
    I would recommend a quality u3 card from a reliable source.
    08-03-2016 08:22 PM
  12. ilordvader's Avatar
    Lexar 1800 micro SD card
    Speed -
    08-04-2016 03:25 AM
  13. shasticat's Avatar
    I will probably get the Samsung Pro Plus 128GB MicroSDXC Memory Card
    08-05-2016 12:29 AM
  14. EMGSM's Avatar
    https://www.amazon.com/Samsung-128GB...cUvbUpU5307733
    I got that same one also and have had no issues...plus it's fast
    08-07-2016 05:54 PM
  15. CehowardNote7's Avatar
    I got the SanDisk 128 and 200, and going to get the Samsung 256 as my free gift for my Note 7.
    I have never had any problems with sd cards.
    08-10-2016 07:30 AM
  16. Kilroy672's Avatar
    How good is the 256 gb card that Samsung is giving away? I'm sure its not top of the line but might be good enough for me.
    08-11-2016 05:03 PM
  17. dkbb's Avatar
    I bought a san disk 200gb card last month, just for the note 7. Should I use it or get the free samsung 256gb card?
    08-12-2016 11:37 AM
  18. Pippinsky's Avatar
    I'm thinking of a samsung pro plus of 64 GB when I get my note
    08-14-2016 09:14 PM
  19. nonie's Avatar
    So is a pro plus a good choice? Should it also say class 10?
    Posted from Android Central.
    on Samsung Galaxy s5
    08-14-2016 10:35 PM
  20. Pippinsky's Avatar
    I'm no expert, but it looks to be the fastest Samsung microsd
    08-15-2016 01:22 PM
  21. ilordvader's Avatar
    08-15-2016 02:03 PM
  22. Preach2k's Avatar
    I would say the one they are offering with the Note 7.
    Free beats paying for one any day!
    08-16-2016 01:48 PM
  23. Preach2k's Avatar
    08-16-2016 03:15 PM
  24. Pippinsky's Avatar
    If I'm eventually going to get an sd card, am I better off having it from the get go? Any advantages? Thanks
    08-17-2016 07:24 AM
  25. Clocks's Avatar
    It is their top of the line card as far as I know
    08-17-2016 08:24 AM
62 123
  1. Replies: 13
    Last Post: 08-20-2016, 11:05 AM
  2. So now that the Note 7 has debuted, would you buy it?
    By SoundofReason in forum Samsung Galaxy Note 7
    Last Post: 08-03-2016, 06:09 PM
  3. Replies: 0
    Last Post: 08-03-2016, 05:30 PM
  4. Samsung Official Note 7 Video
    By H3aTeRzz in forum Samsung Galaxy Note 7
    Last Post: 08-03-2016, 04:55 PM
