How does this work? I got the one from tylt a while back and it didn't work good at all, they even sent me a replacement and same issue, would not keep charging.I use this Wireless Qi charger mount for my Note 5. I'll continue to use it for the Note 7.
How do you have this mounted (the suction cup or the air vent) and how well has the mount held? Also do you use a case on your note 5 and does it charge well through the case. I have one of the Spigen Neo Hybrid cases on order (Spigen says it works with wireless charging)
I have it mounted to the windshield. It holds fine there. I do use a case on my Note 5 now and it charges fine through the case. I am quite happy with this charger overall.
Can you mount it to your dashboard too?
I have this too. I was afraid I wouldn't had been able to remove the mount when I transferred my stuff into my new 2016 Rogue. Today.I've been using the iottie wireless with my Note 5. Great mounts but a little unstable.
iOttie Easy One Touch Qi Wireless Charging Smartphone Mount
I recently switched the mount part to the One Touch 3 and it's much more stable (you can take off the qi cradle and swap mounts).
iOttie Easy One Touch 3 Smartphone Car Mount - iPhone & Android
I've been using a Mountek for years now.
