06-06-2017 02:20 PM
62 123
tools
  1. jayjay234's Avatar
    Purchased today through amazon one day shipping... and I'm honestly blown away. I thought Floss Carter was being too generous at these but this is absolutely mind blowingly good.
    08-19-2016 07:42 PM
  2. Bowlis78's Avatar
    Im so tempted. how about battery...at leat 1.5 hrs for workout via bluetooth...they look amazing.Thanks.
    08-20-2016 11:01 AM
  3. bhatech's Avatar
    Damn you don't make me buy this... Was going to pull the trigger when Flossy reviewed it but it wasn't available then. But now tempting.
    08-20-2016 11:08 AM
  4. anon(632186)'s Avatar
    I saw another review where they were getting like 45 minutes in one ear and an hour in another when streaming. Do you have to have the gear app installed or can you pair like regular earbuds?
    08-20-2016 02:52 PM
  5. MizWylie's Avatar
    Doh. I'd lose them in five seconds.
    Posted from the N7 Dolphin Tears™ on Big Red
    08-20-2016 03:19 PM
  6. kilofoxtrot's Avatar
    ^^^^^ Yup
    08-20-2016 03:21 PM
  7. jdfry15's Avatar
    I'd be all over these if the battery was a little better. Think I'll wait for the next version so they can up the battery. They look pretty slick though.
    08-20-2016 03:21 PM
  8. durandetto's Avatar
    The Samsung guy at best buy said the battery life is 4 hours continuous music. I guess he was mistaken.
    08-20-2016 08:26 PM
  9. jayjay234's Avatar
    Well I'm gonna use this for workout mostly and I don't work out more thab 1.5hours anyway..
    Also if I just play the music directly from the ear piece i get much better battery life.
    08-20-2016 09:34 PM
  10. jayjay234's Avatar
    I think gear app is required... I also noted that the main ear piece (left one for me) had worse battery life than the right one.
    08-20-2016 09:35 PM
  11. jayjay234's Avatar
    Without Bluetooth, BB guy is correct
    08-20-2016 09:36 PM
  12. clerk's Avatar
    Having tried the dash first, the gear iconx are superior in fit connectivity and sound. These things don't move while running, sound decent enough and hold a connection for 20ft. Well worth 200 when everyone else charges 300.
    08-20-2016 09:45 PM
  13. Jaycemiskel's Avatar
    See, I have the dash and I haven't been too impressed with them. My first pair crapped out, and this second pair is OK but sometimes it's like they can't tell that they're in my ear. So these are much better except for the battery life?
    08-23-2016 11:33 PM
  14. j_squared's Avatar
    I just picked these up! Having g got to try to much yet but so far they do sound good.
    08-24-2016 02:08 AM
  15. SSG_Gunz's Avatar
    Gear app is required to sync via Bluetooth to setup and receive calls or notifications. But when you set up music from the gear which I do it works pretty well. And the battery life does even out a bit. I think it just makes me amp up the workout if I know I only have a few hrs of juice.
    08-24-2016 12:27 PM
  16. Bowlis78's Avatar
    i picked the iconx but when you put in the charge...do they keep all day with the green led? is that normal?
    08-24-2016 02:36 PM
  17. Chuck Young's Avatar
    So I have a pair of these and I really like them alot. Went through the Setup>Sounds>Sound Quality and Effects and now they sound great.
    I am still looking for the Gear Icon X PC Manager program, found the one for mac but no X86/64. Anyone know where to get it?
    08-24-2016 08:27 PM
  18. Chuck Young's Avatar
    Oops, read electronic manual and found the install file in the Tools directory of the earbuds.
    fishmd likes this.
    08-24-2016 08:48 PM
  19. Chuck Young's Avatar
    Anyone know if these will pair and play with an ipad?
    08-25-2016 12:39 AM
  20. clerk's Avatar
    The dash never fit me. The BT range was horrible and they were fussy to charge. They always drained while in the case. The Gear fit PERFECTLY at least in MY ear. I have a horrible time getting a good fit with earbuds for running but these babies work great. Battery is what it is. I usually run for an hour. Yesterday, I streamed and the battery drained about 50% . More than enough for my workout purposes which is all I will be using these for. I have noticed some battery drain while in the case after a few days. So you have to keep them charged. I wanted to like the Dash. They are sweet but they are still a work in progress.
    08-25-2016 09:19 AM
  21. kilofoxtrot's Avatar
    Question about ITE buds.
    I have some LG TruTones that are in-the-ear. When I perspire (even a walk on a warm day), I can feel the moisture in my ear canal. Its bothersome to say the least.
    Am I correct that the X's will do the same thing?
    08-26-2016 02:12 PM
  22. clerk's Avatar
    I don't think you can stop that from happening with any bud but some buds are better at keeping sweat from your head from running into your ear. For me, that's usually when the buds slip out. The IconX seal out the sweat nicely which is probably why they stay in my ears. Samsung really nailed the fit on these.
    08-26-2016 04:48 PM
  23. clerk's Avatar
    Green light turns off on mine after a while.
    Bowlis78 likes this.
    08-26-2016 05:06 PM
  24. Jaycemiskel's Avatar
    Yeah, using the Dash outside is a terrible experience. I really want to like them too, especially since I spent 300 bucks on them.
    08-26-2016 06:42 PM
  25. kilofoxtrot's Avatar
    I picked up a pair a couple days ago. They constantly disconnect. The left one (non-phone) more than the right.
    Even when connected, my Audible app pauses often... to the point of uselessness. Listening to audio books is one of my main reasons for using these.
    I have tried different hoops and ear gels. Nada.
    I am probably going to have to return them. Its a shame... I really liked them when they worked.
    08-28-2016 10:16 AM
62 123
  1. Gear Fit 2 + Note 7 --> notifications are not working!
    By freeideasguy in forum Samsung Galaxy Note 7
    Last Post: 01-30-2017, 04:13 PM
  2. For those with the Note and a Gear S2 3G
    By me23brown in forum Samsung Galaxy Note 7
    Last Post: 11-07-2016, 04:48 PM
  3. Gear fit2 distance wildly inaccurate
    By Clocks in forum Samsung Gear Fit 1 & 2
    Last Post: 09-02-2016, 06:36 AM
  4. Process to get Gear 2 or SD card
    By spasell in forum Samsung Galaxy Note 7
    Last Post: 08-20-2016, 11:31 AM
  5. Gear Vr - daydream
    By jj2339 in forum Samsung Galaxy Note 7
    Last Post: 08-19-2016, 06:37 PM
