1. Jewels81's Avatar
    Ok its been like 15 minutes since I've applied the skin/protector on my note 7. To my surprise the edges are sticking very well so far. I know they say it can take up to 48 hours for all bubbles to go away. Since the solution for putting the skin on I had to use dish washing liquid and water for keeping fingerprints off and to be able to easily move skin around if i need to adjust it. Well the skin fits but now my screen got a cloudy water effect to it and it is annoying as heck. My question is since it takes up to 48 hours to get all bubbles out will that cloudy water look be gone too? If not I'm only going to be able to keep it on long enough til I find something else.
    08-29-2016 11:22 PM
  2. Jewels81's Avatar
    I also notice the skin can interfere with the edge feature making it hard to get it to open sometimes
    08-29-2016 11:37 PM
  3. AhemThisGuy's Avatar
    So far this skin on my phone looking good. The side edges sticking really good and corners as well.
    Jewels81 likes this.
    08-30-2016 05:54 AM
  4. Jewels81's Avatar
    Yes I love it
    08-30-2016 06:17 AM
  1. blackberry user moving to note 7?
    By squashthatfly3 in forum Samsung Galaxy Note 7
    Last Post: 09-12-2016, 09:08 PM
  2. "Congratulations Verizon User You have won!" malware popups
    By recDNA in forum Samsung Galaxy Note 7
    Last Post: 09-02-2016, 06:49 AM
  3. China.samsung.com.army.home???
    By Rackem_n_crackem in forum Samsung Galaxy S6
    Last Post: 08-30-2016, 01:50 AM
  4. Note 7 preorder from samsung.com
    By 1joeyisbest in forum Samsung Galaxy Note 7
    Last Post: 08-29-2016, 02:52 PM
  5. how do I remove vtext.com from my computer ?
    Last Post: 08-28-2016, 08:45 PM
