Mooncatt
Ambassador
Re: The Note 7 lives on at Verizon. Just left the Verizon store and called Billing Support to confir
The problem is the high temps don't cause the battery to go up. The internal short or whatever is triggering the runaway reaction is what causes the excessive heat, at which point it's too late.Exactly. If people are concerned about battery temperature there are several good monitoring applications to do so.
