I know the Snapdragon 820 equipt S7's have given people fits... I was wondering if there have been any leaks as to how chained up the Note 7 (either version) will be?
Man I asked the question and no answer I bought this s7 Tmobile and it was locked down but we do have root now for the S7 hopefully note 7 will be unlocked
With Package Disabler Pro that will allow you to disable anything, I haven't had a need for rooting a Samsung.
There are no ads, it is a paid app. It wasn't that much, a couple of bucks.I understand the reviews on Google Play can be subjective and sometimes bogus. Since you have this app, does it perform as advertised? Do you get killed with ads? Battery sucker? I'd like a real world user review. Thanks!
You can disable everything, even some
system files, so you have to be careful with it. It doesn't run in the background. You just choose what to disable and then close it down.
Here is a screenshot of a few that usually require root to disable
//uploads.tapatalk-cdn.com/20160810/64740f40e119a23eb938c8d121a04f4c.jpg
There's other need besides disable bloat for root. Wifi tether router for one (free hotspot) amongst other things.With Package Disabler Pro that will allow you to disable anything, I haven't had a need for rooting a Samsung.
Please forgive if this is a bit of a noob response. ( this is my first post on android central!), but isn't it possible to disable any app note from within Android app management?
I haven' t rooted a Samsung phone since the Note 4. I really haven't had a need anymore. You can disable almost all of the Samsung apps (although I use most of them), and Tmobile gives me 7GB of tethering a month ( hardly use it anymore).
I tried rooting my S7 Edge so I could use Adaway
