09-23-2016 04:24 AM
30 12
tools
  1. LeoRex's Avatar
    I know the Snapdragon 820 equipt S7's have given people fits... I was wondering if there have been any leaks as to how chained up the Note 7 (either version) will be?
    08-04-2016 01:44 PM
  2. Marc Blackwell's Avatar
    Man I asked the question and no answer I bought this s7 Tmobile and it was locked down but we do have root now for the S7 hopefully note 7 will be unlocked
    08-07-2016 06:22 PM
  3. boufa's Avatar
    Root has gone the way of the removable battery, the IR blaster and the dinosaur... at least on AT&T. I have given up on that even being a factor in the ownership of the device. Those days are gone, and I seriously doubt they will ever come back.
    mcook1670 likes this.
    08-07-2016 11:00 PM
  4. Kelly Kearns's Avatar
    With Package Disabler Pro that will allow you to disable anything, I haven't had a need for rooting a Samsung.
    DiNgL3HoPp3r likes this.
    08-08-2016 12:00 AM
  5. NexusGirlX's Avatar
    I tried rooting my S7 Edge so I could use Adaway but gave that up and restored to stock after two weeks. Even after adjusting the CPU cores and making other adjustments, the battery life and lag was far worse then my non rooted S7 Edge. Plus with a locked boot loader, you can't use any custom ROMs.
    I think it's very likely that the Note 7 will be locked as well. It's just the way Samsung is going in the US. T-Mobile blamed Samsung for this.
    08-08-2016 10:09 PM
  6. ibcop's Avatar
    I understand the reviews on Google Play can be subjective and sometimes bogus. Since you have this app, does it perform as advertised? Do you get killed with ads? Battery sucker? I'd like a real world user review. Thanks!
    08-10-2016 11:53 AM
  7. Kelly Kearns's Avatar
    There are no ads, it is a paid app. It wasn't that much, a couple of bucks.
    You can disable everything, even some
    system files, so you have to be careful with it. It doesn't run in the background. You just choose what to disable and then close it down.
    Here is a screenshot of a few that usually require root to disable
    ibcop, toneofark and dkbb like this.
    08-10-2016 12:03 PM
  8. ibcop's Avatar
    https://uploads.tapatalk-cdn.com/2016...d121a04f4c.jpg
    Awesome sauce. Thanks.
    08-11-2016 10:21 AM
  9. toneofark's Avatar
    This is good to know. Seriously considering the Note, after all these years of iPhoning.
    08-11-2016 01:43 PM
  10. bushy73's Avatar
    Please forgive if this is a bit of a noob response. ( this is my first post on android central!), but isn't it possible to disable any app note from within Android app management?
    08-14-2016 06:08 PM
  11. bushy73's Avatar
    I really hope root will be possible as I really like using Titanium backup.
    Highrisedrifter likes this.
    08-14-2016 06:11 PM
  12. importcraz's Avatar
    There's other need besides disable bloat for root. Wifi tether router for one (free hotspot) amongst other things.
    blopez24 likes this.
    08-16-2016 12:31 AM
  13. mcook1670's Avatar
    I haven' t rooted a Samsung phone since the Note 4. I really haven't had a need anymore. You can disable almost all of the Samsung apps (although I use most of them), and Tmobile gives me 7GB of tethering a month ( hardly use it anymore).
    08-18-2016 11:46 AM
  14. bable's Avatar
    It's partially the concept for me, if I buy a device then I want root command privileges. Even if I never use them...
    08-18-2016 08:21 PM
  15. jlczl's Avatar
    It us possible to disable SOME apps thru Android management but with this app you can disable more plus the process is much simpler and less tedious as disabling apps thru Android require 2 to 3 clicks per app.
    via S7 Active Beast -- Peerless Note 4 -- Beautiful Note 7
    08-21-2016 08:19 AM
  16. importcraz's Avatar
    I burn through 14gb . As I hotspot in my vehicle.
    08-21-2016 08:31 AM
  17. pool_shark's Avatar
    I agree, there is also complete backups for all apps with data, all apps in multiview, and my personal favorite, a terminal emulator with BusyBox for access to the command line.
    08-21-2016 08:02 PM
  18. abtm's Avatar
    08-21-2016 11:45 PM
  19. NexusGirlX's Avatar
    That's the Exynos model. I haven't seen anything posted yet on XDA about the model sold in the US. The boot loader is locked for the US version just like the S7/Edge.
    08-22-2016 01:19 AM
  20. TJA3500's Avatar
    Have tried Adgaurd? It doesn't require root.
    08-22-2016 01:32 PM
  21. NexusGirlX's Avatar
    I am using it on my S7 Edge. Sometimes though, having the constant Adguard notification on the dropdown gets annoying. This is why I have my Note 5, Note 4 and Note Edge all rooted so I can use Adaway.
    I don't have a Note 7 at this time. Not sure if I will skip this year or not.
    08-22-2016 01:36 PM
  22. Strong_Genetics's Avatar
    Times have changed haven't they....I remember when a phone came out the forums were flooded day one with everyone looking for root...I've been around since the hot thing was getting free tethering through root.....Now I have no need to even want root....
    08-23-2016 10:14 AM
  23. eyecon82's Avatar
    Only reason why I want root is for free hotspot
    08-23-2016 10:18 AM
  24. bushy73's Avatar
    Just discovered I csn do all my complete backups with Helium without root. It's not Titanium Backup that's good sure, but I have less urgency to root now.
    hailsusy90 likes this.
    08-23-2016 07:49 PM
  25. mbar9607's Avatar
    i haven't had an android phone in a while since i've basically switch to all apple products but i do browse around here still from time to time, and i see root like jailbreak there's not a lot of use for it any more and than the fact of "because i can" but that's just my opinion on it
    08-25-2016 08:50 PM
30 12
  1. Will the HTC One M8 GPE receive the android n update?
    Last Post: 11-01-2016, 04:25 PM
  2. Carrier Versions of the Note7 support identical LTE bands?
    By Dr Claw in forum Samsung Galaxy Note 7
    Last Post: 08-07-2016, 08:40 PM
  3. Replies: 0
    Last Post: 08-04-2016, 01:40 PM
  4. Replies: 1
    Last Post: 08-04-2016, 01:37 PM
  5. Replies: 0
    Last Post: 08-04-2016, 01:35 PM
