D13H4RD2L1V3
Retired Moderator
Re: Will You Fork Over the Cash?
While having more memory would be nice, especially on the spec sheet, the value of having more is really only seen when you're actively using that extra memory on a regular basis. If there's no phone actually utilizing all 6GB of memory to its full potential, then it's basically a selling point without any significant improvement in real-world user experience whatsoever until an OEM manages to make a phone that takes full and complete advantage of all 6GB of memory.
While a Note7 with 6GB of memory would be nice, 4GB is still more than plenty for many usage patterns. In fact, if a Note7 with 4GB of memory is real, it could mean that Samsung is focusing on optimizing their software to improve RAM management and utilization instead of just tossing more RAM to alleviate the issue. IMO, this is a better way to improve memory utilization as it means you are actively working to improve how your software consumes and manages memory so that it takes full advantage of whatever memory is available. The Exynos S7 (at least) has far better memory management than its predecessor, so it would only make sense that they would continue optimizing their software for the Note7.
Here's the thing.7GB is basically just not happening. Bad rumor. Different carriers having different specs is possible but I don't think it's likely. But even if that happened, there's an important thing to remember. There are zero phones on the market that are actually utilizing 6GB of RAM. Android Marshmallow and Nougat can both run beautifully on 2GB of RAM, so 4 should be more than enough - and if it's not, then something is wrong on the OEM implementation of memory management, not the OEM's choice of specs.
