recDNA
Re: The Note 7 Detailed
Are any genuine specs available? I mean only 2 weeks to release shouldn't they be?
Nothing confirmedAre any genuine specs available? I mean only 2 weeks to release shouldn't they be?
So amaturish question here... If I have all the accessories for USB Quick charge for my G4....can I use any of it for USB-C? I know the shape is different but can I use the bricks or the car charger Aukey quick charge part for example? I assume not... but thought I would check...
Samsung
Galaxy Note 7
Platform
Android with TouchWiz Grace UX
Display 5.7-inch Super AMOLED 1440 x 2560-pixel resolution
SoC Snapdragon 821 in the United States
Samsung Exynos 8893 in other markets
RAM 6 GB
Storage 64 GB expandable via microSD cards
Camera 12-megapixel f/1.7 with Dual Pixel AF
5-megapixel front cam
Battery 3,600 mAh
Extra features Iris scanner, IP68 water protection
Source
Yes, there are many Type A to C cables that can work for that. So the brick and car port side would still be USB type A and Type C on the other end. But they won't function necessarily as QuickCharge unless Samsung's new adaptive fast charging is still compatible with either QC 2.0 or 3.0. So you might just get normal charging speeds, depending on how they implemented it. Remember be careful to read reviews when buying USB C cables to make sure you're not buying a hunk of junk.
QC 3.0 devices are backwards compatible with 2.0 chargers. They actually charge at the same speeds too, the difference is power efficiency.Thanks. My Aukey brick and Aukey car adapter are QC2. So was wondering if I need to buy all new stuff. Sounds like I might to get QC3.
Samsung
Galaxy Note 7
Platform
RAM 6 GB
Battery 3,600 mAh
Source
More ram but same battery as the S7 Edge, may not be a good thing.
I'm thinking it'll be about the same cause the screen is bigger plus you've got to power the extra ram.With the 821 Snapdragon processor the battery will probably do better in this phone.
Looks like the flat "lite" version. The edge version might have 6gb but unless it has bigger battery, it might as well be 4.Seems like 4GB of memory could likely be making the cut.
Some might be disappointed and while I would have loved 6GB, 4GB is way more then plenty for me.
It might seem that Samsung is going for software optimization instead of just throwing more memory, a move that I strongly approve with open arms.
Possibly, but I'm just keeping my expectations fairly low to avoid being overly let down.Looks like the flat "lite" version. The edge version might have 6gb but unless it has bigger battery, it might as well be 4.
