Preach2k
I seen a video where someone said that it was thinner then the Note 5. I think it was from Pocket Now.I thought it was rumored to be 7.9mm thin? That's 0.2mm thicker than the Note5.
Well...at this point I probably shouldn't be surprised. The edged screen, non-removable battery, I was already looking away fromt it. Seriously how can an s7 active have 4000mAh battery and this giant note can't? I understand the space of the s-pen slot can be an issue but i thought battery technology has increased since then, and 500mAh decrease from what it originally was? I can only hope that Android 7 will not be as battery-consuming as Lolipop was.
That was just Jaime making an assumption based on how it looked.I seen a video where someone said that it was thinner then the Note 5. I think it was from Pocket Now.
Same Samsung needs to understand that the Note should be the top of the line function over form device. If people want a fancy looking phone that's what the S and especially edge line is for.Well...at this point I probably shouldn't be surprised. The edged screen, non-removable battery, I was already looking away fromt it. Seriously how can an s7 active have 4000mAh battery and this giant note can't? I understand the space of the s-pen slot can be an issue but i thought battery technology has increased since then, and 500mAh decrease from what it originally was? I can only hope that Android 7 will not be as battery-consuming as Lolipop was.
It would be nice but sadly it isn't the case. Maybe the Note isn't for you?Same Samsung needs to understand that the Note should be the top of the line function over form device. If people want a fancy looking phone that's what the S and especially edge line is for.
The note should be a no BS, gimmicks productivity device as far as mobile phones can be used for productivity .
With a bigger phone there are more pixels to push, so a bigger battery will be needed...can't believe people are still falling for marketing crap like software optimization and even if that existed a bigger removable battery would still be better than every alternative.
Not exactly exited but it will be interesting to see if Samsung can take back the Note line to it's former glory instead of just making it a bigger S line device with an S Pen.
Well I have the Note 4 so the line is for sure for me.It would be nice but sadly it isn't the case. Maybe the Note isn't for you?
I'll reserve my judgement on battery claims for real world results. So many times people judge on specs and the opposite happens.
Not for nothing but August 2nd is ........ NEXT week already !!!!!We must remember these are all rumors until we get the Official announcement on August 2nd.
I guess as we get closer to this date we all become even more impatient ??
If we could place preorders in that day or even the next day then that'll be my gameplan
Guilty as charge !!!!!Wait, these nerds are going to get MORE impatient?!
2750mAh.How big is the battery in the iPhone 6s Plus?
In the world of batteries and power, it's more complicated than just mAh numbers and energy efficiency percentage improvements.Guess mAh isn't the answer. Maybe this is more complicated than 100 mAh.
Yup. Battery size is only directly comparable when the device is identical. Even with very similar specs like the s6 and Note 5,the note 5 was around 15-20% larger battery, but got like 50% if not more battery lifeIn the world of batteries and power, it's more complicated than just mAh numbers and energy efficiency percentage improvements.
