According to SamMobile, the Galaxy Note7 may feature a battery that is 3500mAh in capacity. This is based on information released by a Korean carrier for the SM-N930S variant of the Note7.
Bear in mind that while this is a 100mAh decrease from the Galaxy S7 edge, it is a healthy 500mAh upgrade from the Note5, along with improved efficiency in its internals such as the display and processor.
It may be soon to tell, but the Note7 may feature some efficiency improvements over the S7 edge that could give it identical battery life.
What do you guys think? Personally, while it is mildly disappointing, this is still a significant step up from my old phone, both in battery capacity and efficiency, which means that I should have no issue getting this phone to last the day on a single charge. While I would like more, 3500mAh plus the more efficient internals is more than sufficient for my daily usage pattern.
Of course, your mileage may vary, as everyone has different usage patterns.
New leak points towards the Galaxy Note 7 sporting a 3,500mAh battery - SamMobile
(LG G3 - Android 6.0)
