08-01-2016 06:25 AM
180 123 ...
tools
  1. D13H4RD2L1V3's Avatar
    According to SamMobile, the Galaxy Note7 may feature a battery that is 3500mAh in capacity. This is based on information released by a Korean carrier for the SM-N930S variant of the Note7.
    Bear in mind that while this is a 100mAh decrease from the Galaxy S7 edge, it is a healthy 500mAh upgrade from the Note5, along with improved efficiency in its internals such as the display and processor.
    It may be soon to tell, but the Note7 may feature some efficiency improvements over the S7 edge that could give it identical battery life.
    What do you guys think? Personally, while it is mildly disappointing, this is still a significant step up from my old phone, both in battery capacity and efficiency, which means that I should have no issue getting this phone to last the day on a single charge. While I would like more, 3500mAh plus the more efficient internals is more than sufficient for my daily usage pattern.
    Of course, your mileage may vary, as everyone has different usage patterns.
    New leak points towards the Galaxy Note 7 sporting a 3,500mAh battery - SamMobile
    (LG G3 - Android 6.0)
    07-22-2016 02:37 AM
  2. ratsttam's Avatar
    If it means anything, I had used the Note 4 streaming Pandora for 8+hrs at a time at work, browsing some social media, chatting with my Lady, etc..., and still had plenty of battery left. The Note 5 does even better. I can just imagine how much longer a 500mah increase would go, when the rest is more efficient at using the power.
    07-22-2016 06:04 AM
  3. Preach2k's Avatar
    I hope that this is not true. How can The Note 7 have an smaller battery then the S7!
    recDNA likes this.
    07-22-2016 06:20 AM
  4. billyhousemover's Avatar
    Every year it's the same. Great expectations and then two weeks out Sammy brings us back to reality! Sure hope the speaker isn't moved to the back! Pre-ordered n5 last year but waiting a couple of weeks for reviews this time. Still think this little phone-computer is going to be a beast!
    Premium1 likes this.
    07-22-2016 06:20 AM
  5. Shepx13's Avatar
    I'm not that concerned. It's definitely going to be way better than my 6p is so I'll be happy with that
    07-22-2016 06:56 AM
  6. thegame161's Avatar
    Smaller battery doesn't mean less battery life
    PlaybookFanatic and TJA3500 like this.
    07-22-2016 07:38 AM
  7. D13H4RD2L1V3's Avatar
    Well, there are some reasons why.
    1) The S Pen. The S Pen slot actually takes up quite a bit of internal space. So there isn't actually as much room for a bigger battery compared to a phone without said slot.
    2) Despite the larger screen size, note that the bezels may actually be slightly thinner. So the overall size may not increase that much, meaning that there also isn't as much space for a larger cell.
    I know some fans will feel a little let-down by having a Note that actually has a slightly smaller battery than the S7 edge, but I personally wouldn't have sleepless nights over a 100mAh difference in capacity.
    It's also worth noting that the Note seems to have more efficient kernel management compared to the S-line, so battery life should be identical or maybe even better.
    Preach2k and Almeuit like this.
    07-22-2016 08:41 AM
  8. Preach2k's Avatar
    The phone is still an update from my Note 4!
    07-22-2016 08:47 AM
  9. bhatech's Avatar
    3500 will be super disappointing considering the S7 edge has the 3600. I hope they have at least 4000.
    recDNA likes this.
    07-22-2016 09:34 AM
  10. bhatech's Avatar
    What do mean they have more efficient kernel management? Even if they have initially wouldn't that be pushed to S7 edge as well in updates?
    recDNA likes this.
    07-22-2016 09:36 AM
  11. D13H4RD2L1V3's Avatar
    It's weird, but the Notes usually have slightly more efficient kernel management compared to the S-line.
    Under load, both consume the same amount of power. But when idle, the Note sips less power for some reason. It's also quicker to reach idle speeds.
    LeoRex likes this.
    07-22-2016 09:47 AM
  12. Shepx13's Avatar
    The Note has to account for the stylus. Stressing about a minor difference is crazy.
    Preach2k likes this.
    07-22-2016 10:47 AM
  13. mlbyanks11's Avatar
    Yes it does. Note 5 battery sucks the note 4 was way better.
    recDNA likes this.
    07-22-2016 11:34 AM
  14. D13H4RD2L1V3's Avatar
    Depends on how you use your phone.
    If you're a heavy user, there's no question. A smaller battery just won't outlast a bigger one.
    If you're a lighter user, then the tables might actually turn, especially since efficiency improvements in hardware and even software can make some phones with smaller batteries last a little longer than usual.
    Of course, the best combo is having both, and regardless of whether it's 3500mAh or 4000mAh, it's still the largest battery ever fitted onto a Note device.
    07-22-2016 11:41 AM
  15. dlgus's Avatar
    I guess I am weird...I like my battery to last, but I LIVE with a battery pack in my purse so <shrug>
    07-22-2016 11:42 AM
  16. debdroid1a's Avatar
    Those who aren't into specs want that thin phone. But when the phone doesn't last as long as their friends S7E, it will matter.
    Would you rather have a larger phone so it would accommodate a bigger battery and the spen?
    Posted via the *Note 5*
    07-22-2016 11:54 AM
  17. D13H4RD2L1V3's Avatar
    Uh, I'll answer that last question later.
    But I'm pretty sure that this could last as long as an S7e, maybe slightly longer, though that's on mixed usage patterns where the phone is asleep quite often.
    Because, as I said above, the Note-line, weirdly, has a different kernel where it goes back to idle in a quicker fashion than the S-line.
    To answer your question, if I had my way, I would rather carry a 10mm behemoth with a 6000mAh battery. That likely won't appeal to most people, though.
    msndrstood likes this.
    07-22-2016 12:05 PM
  18. Almeuit's Avatar
    I don't have issues on the Note 5 I'm using.
    07-22-2016 05:14 PM
  19. CehowardNote7's Avatar
    I do a little better, I live with 3 spare batteries for my Note 4.. Good thing too. This morning had to make a trip to the ER, and they kept me. My phone going full blast calling people looking at movies. No charger with me, or one available. But, 20 hours later, my phone still at 100% thanks to two quick 20 second swap outs.. I have a battery pack(not with me), but spares are way faster, and easier to carry.. I am going to miss my removable battery of my beloved Note 4, miss it dearly.
    07-22-2016 05:44 PM
  20. ThrottleJohnny's Avatar
    Note 5 battery is excellent.
    Aquila and TJA3500 like this.
    07-22-2016 05:53 PM
  21. dpham00's Avatar
    I would be ok with 3500.
    07-22-2016 05:55 PM
  22. Almeuit's Avatar
    Likewise. I was hoping for a bigger one (who wouldn't want more battery?) but .. I can live with it. I have a fast charging battery pack and chargers everywhere so I am not concerned. Quick charging made me stop worrying about battery.
    Aquila likes this.
    07-22-2016 06:43 PM
  23. Carrtman's Avatar
    Lesser capacity than the s7 edge? only way this is acceptable if Samsung brings back the removable battery
    nothing beats going from almost empty to 100 percent in 20 seconds
    CehowardNote7 likes this.
    07-22-2016 09:54 PM
  24. ThrottleJohnny's Avatar
    Again, the Note 5 was 3000 and had perfectly acceptable battery life.
    Aquila likes this.
    07-22-2016 11:08 PM
  25. D13H4RD2L1V3's Avatar
    Sorry to burst your bubble, but it is pretty much unlikely that Samsung is going to be bringing back the removable battery. Given that they are focused on their current design language, a removable battery is pretty much impossible to implement.
    Thing is, one Android OEM is sticking with that philosophy on their flagships. LG.
    Although the G5 has been rather underwhelming, the V20 might be the one to pay attention to if you want a removable battery.
    recDNA likes this.
    07-23-2016 12:30 AM
180 123 ...
  1. Why did a pink line apear on my galaxy samsung s7 edge
    Last Post: 07-24-2017, 12:21 PM
  2. How to fix and where is the lcd cord on my tab 3 SM-T217S
    Last Post: 07-26-2016, 08:22 AM
  3. Replies: 2
    Last Post: 07-25-2016, 06:07 PM
  4. Replies: 0
    Last Post: 07-22-2016, 02:17 AM
  5. See text messages in call log on Samsung Galaxy S7?
    By AC Question in forum Samsung Galaxy S7
    Last Post: 07-22-2016, 01:44 AM
