skatergirl
Retired Moderator
Thanks for the link.
3100 mah sounds great, but the description of the battery pack states that it will go on to charge the N7 battery up to only half of the N7's 3500 mah capacity. Still, if I could get 5250 mah total, that would be more than enough for a heavy day's outing. I wonder, however, whether it charges quickly enough, especially if you are charging while using the phone.
I too noticed about charging half. I wonder if you slap on that pack and use it first would you get more out of the pack and once the pack is drained start using your phone's battery?
