1. droidbillh's Avatar
    I'm pretty familiar with both phones and would like to find out what others would recommend.
    I'm leaning towards the Note 7 as long as the Edge Feeds look good.
    Appreciate any feedback.
    Thank you !
    08-04-2016 09:52 PM
  2. D13H4RD2L1V3's Avatar
    Hey there!
    Deciding between the S7 edge and Note7 depends on these variables.
    • Do you use the S Pen frequently?
    • Does the extra 0.2" of screen space matter?
    • Are you intrigued by the new features of the Note7?
    • Is budget an issue?
    • Do you need that extra 100mAh capacity on the S7e?
    I would recommend the Note7 if you want a slightly larger display, use the S Pen frequently and are intrigued by the new features, as long as you can afford one. However, if you don't use the S Pen frequently, don't care for the new features but still want a reasonably large display, I'd recommend the S7 edge instead.
    droidbillh likes this.
    08-04-2016 09:56 PM
  3. droidbillh's Avatar
    I really like the idea of extra security with the Iris scanner. The S Pen is something I haven't used before but could see using to take quick notes or reminders. I really like the ability to create GIFS. Plus it's 64gb. The big thing for me is I want to see the feeds on the side panel and how big they are.
    08-04-2016 10:10 PM
  4. D13H4RD2L1V3's Avatar
    If you can't decide, consider taking a trip down to a Best Buy or your local carrier store to give both phones a look. It would really help in deciding which one to get.
    droidbillh and MRS DIVA like this.
    08-04-2016 10:16 PM
  5. dsignori's Avatar
    Honestly between the 2, I don't know any advantage of the S7E, other than price - if buying the phone outright. (I seriously doubt the 100 Mah battery difference will be noticeable between the 2).
    Even if you don't use the S-Pen, you get 64gb of base storage, new HDR screen, and yes, the iris scanner and cool new S-Pen stuff (and cool gifts like a Gear fit 2 or 256gb sd card)
    To me I can't see a good reason to go with the S7E at this point in time, unless it is a price issue for buying outright.
    08-04-2016 10:26 PM
  6. ctown81's Avatar
    The storage space is what won me over. Of it weren't for that I'd go with the edge
    08-04-2016 10:40 PM
  7. jisddwqs's Avatar
    The main reason I don't purchase S7 is that it doesn't support Type C. Type C is the coolest thing for a phone. Personal opinion.
    08-04-2016 10:52 PM
  8. bhatech's Avatar
    Type C
    Newer software
    Iris scanner
    Gorilla glass 5
    S Pen
    64 GB
    Better Ergonomics with bigger screen
    Killer colors
    Finally, just get the new one. Newer is better is bang on here !!
    08-04-2016 11:03 PM
  9. udnh's Avatar
    What would be the advantages of an iris scanner over the fingerprint reader? Something useful for the average user.
    08-05-2016 07:41 AM
  10. russel5150's Avatar
    I said it the other day and i stand by it,
    The note7 doesn't feel to me like an s7 edge with an s pen, it feels like a note with an edge screen. The note stuff is there, it feels like a note when you hold it, but that's my opinion lol.
    The s7 edge is an awesome phone, but i cant wait to get the note7 and pass the s7 edge down..
    Poppy59 and droidbillh like this.
    08-05-2016 07:49 AM
  11. droidbillh's Avatar
    Here are what the notification feeds look like
    anon(782252) likes this.
    08-05-2016 09:03 PM
  12. bhatech's Avatar
    Here is nice comparison video between S7 edge and Note 7
    08-05-2016 09:24 PM
  13. archer75's Avatar
    It also gets 9000 more points than the S7 on Antutu benchmarks. It supports the vulken API which apparently the s7 edge does not. Also has a chip for processing HDR video. Samsung has a partnership with amazon for streaming HDR video. Samsung browser supports extensions. And everything else in post #8
    I know there's something else i'm forgetting.
    08-05-2016 11:09 PM
  14. JeromeM's Avatar
    For someone like me going to a carrier and buying on contract (Rogers in Canada) Note 7 is $159 more but they are giving 64GB SD card and either the Gear Fit 2 or a Bluetooth speaker (both with CDN MSRP if $249) with pre order so my guy math says Note 7 is cheaper.
    08-05-2016 11:45 PM
  15. bplink95's Avatar
    display size. I love my s7 edge but spen and display size is why I pre ordered blue coral note 7.
    08-06-2016 12:52 AM
  1. Stylus without an offset for Note Pro 12.2?
    By AlexAndAHalf in forum Samsung Galaxy Note Pro 12.2
    Last Post: 08-07-2016, 08:56 PM
  2. Wallet Cases and Edge Functionality
    By dchanson in forum Samsung Galaxy Note 7 Cases & Accessories
    Last Post: 08-07-2016, 08:45 PM
  3. Samsung Galaxy Tab A 7.0
    By andriodbill in forum More Samsung Tablets
    Last Post: 08-05-2016, 03:54 PM
  4. Flashing roms to us variant s7
    Last Post: 08-04-2016, 09:41 PM
  5. My Samsung Galaxy s6's screen isn't turning on?
    Last Post: 08-04-2016, 08:34 PM
