08-10-2016 08:10 AM
40 12
tools
  1. boufa's Avatar
    I'll do face down if you show me a slim sexy case that has that little lip... I'm not gonna get a big stupid case just so I can put my phone face down. It never how's face down because I don't want to damage the screen. I like the idea, though...
    Slim and sexy... hmmm, I somehow doubt my opinion of that and yours would be different. lol ... https://www.amazon.com/gp/product/B0...cUvbUpU5308052 this is the one I have. It has a the lip on the front. They run about 1-2mm. Just enough to keep screen and desk from kissing.
    ihbsbA likes this.
    08-07-2016 09:43 PM
  2. ihbsbA's Avatar
    Slim and sexy... hmmm, I somehow doubt my opinion of that and yours would be different. lol ... https://www.amazon.com/gp/product/B0...cUvbUpU5308060 this is the one I have. It has a the lip on the front. They run about 1-2mm. Just enough to keep screen and desk from kissing.
    I think I just ordered that one! Rose gold, lol
    08-07-2016 09:47 PM
  3. ihbsbA's Avatar
    Slim and sexy... hmmm, I somehow doubt my opinion of that and yours would be different. lol ... https://www.amazon.com/gp/product/B0...cUvbUpU5308065 this is the one I have. It has a the lip on the front. They run about 1-2mm. Just enough to keep screen and desk from kissing.
    Galaxy Note 7 Case, Spigen® [Ultra Hybrid] AIR CUSHION [Rose Crystal] Clear back panel + TPU bumper for Samsung Galaxy Note 7 (2016) - (562CS20558) https://www.amazon.com/dp/B01GIUIDS6...cUvbUpU5308065
    This is the one I ordered...
    08-07-2016 09:49 PM
  4. ayush_banka's Avatar
    I'll be curious to see if it still works with Nova.
    All of the features of S-Pen or Edge will work regardless of what launcher you use.
    recDNA likes this.
    08-08-2016 05:12 AM
  5. recDNA's Avatar
    Do edge features come up within an app like Tapatalk?
    08-08-2016 11:20 AM
  6. Jean Sagarese's Avatar
    If I had that feature it would alert me to texts I may have missed from a family member and when of them gets testy if I don't answer quickly it would be great
    08-08-2016 11:45 AM
  7. gogoplata1980's Avatar
    I believe it works with any app that doesn't go landscape like games, etc.
    08-08-2016 11:56 AM
  8. recDNA's Avatar
    Cool. Might use it after all
    08-08-2016 11:57 AM
  9. rushmore's Avatar
    I have yet to see the Edge ticker style apps actually work correctly or at all on the N7. Even if they work, the will not be as legible as the flatter Edge surface (ironic), but distorted on the curve. The other Edge apps that use the swipe stripe still seem to have no functional value than swiping from the sides of a flat display to show the same panels. What is the functional gain? I have tried the apps on the Note 7 and similar type apps on the Note 5. Not seeing any functional advantage of the curve besides the thinner width.
    08-09-2016 09:56 AM
  10. donebrasko's Avatar
    I hope this isn't just a cosmetic thing
    08-09-2016 10:19 AM
  11. TX Jedi's Avatar
    S7 Edge: Everything No One Told You About The Edge Screen
    08-09-2016 10:30 AM
  12. boufa's Avatar
    The problem with the n7 and ticker tape scrolls is that the edges that made the most use of them was the gentler edges of the earlier devices. The scrolls are likely worthless on the n7. The side panels have an advantage over flat screen versions in 1 key way... the trigger "handles" are out of the way on the side screen when not in use. I find myself moving around things like the airpanel trigger spit, because it always seems like it's in the way.
    08-09-2016 11:22 PM
  13. NotAnAppleGuy's Avatar
    Wait? The Edge panel has the same functionality as my current Note Edge?!?!??!
    Posted Via Galaxy Note Edge. Yea, the phone is perfect...
    08-09-2016 11:27 PM
  14. rushmore's Avatar
    Probably not with the ticker apps.
    08-10-2016 07:21 AM
  15. boufa's Avatar
    Sure they both make phone calls, and they both send text messages, can surf the web, and I would imagine that the edge stuff is the same. I would hardly consider that to anything being equal.
    I can walk talk and breathe, but I'm no NFL player.
    08-10-2016 08:10 AM
40 12
  1. Edge turning off, very unstable
    By Toby01 in forum Samsung Galaxy Note Edge
    Last Post: 08-09-2016, 01:28 PM
  2. Kogan S7 Edge variants
    By Christine Aflak in forum Samsung Galaxy S7 edge
    Last Post: 08-09-2016, 01:38 AM
  3. S7 & S7 Edge people, what are the battery saving tips
    By w7sg in forum Samsung Galaxy Note 7
    Last Post: 08-07-2016, 10:07 PM
  4. Why won't my GS6 edge fast charge anymore?
    Last Post: 08-07-2016, 12:31 AM
  5. Sgs7 edge: audio stuttering
    Last Post: 08-06-2016, 11:19 PM
