1. boufa's Avatar
    I am reading through the T-mobile manual, that was posted on XDA. I found a few interesting things....
    Apparently you can use your Note 7 to charge another device....
    "Reverse Charging
    The included USB Connector allows you to charge
    another device through a USB cable. When connected,
    your battery is used to charge the other device, and "
    Notes.... it looks like there are no more action memos. All s-pen notes will be the same. I knew they were combining the apps, but I figured there would still be a difference between a quick note, and a more 'formal' note.
    T-mobile still has download booster.
    It looks like T-Mo also has wifi calling on it.
    Night Clock
    Set up a clock that displays on the Edge screen
    when the screen is off. Night mode is available for a
    maximum of 12 hours.
    This was news to me... I wonder what other edge features there might be.
    App power monitor: Put apps to sleep so that
    they do not use battery power when not in use.
    Tap Save power to enable.
    • Unmonitored apps: Select apps to exclude from
    being put to sleep by the App power monitor.
    These options are in the battery settings... is this part of Doze?
    Auto Restart
    Optimize your device by restarting it automatically at
    set times. The device only restarts if it is not in use and
    battery power is more than 30%.
    A great idea.
    08-08-2016 12:01 AM
  2. D13H4RD2L1V3's Avatar
    I know that USB-C allows the use of the port to send power in Android Marshmallow.
    Would be fun to use my Note7 as a battery bank. xD
    08-08-2016 12:09 AM
  3. Arsenio Martins's Avatar
    Yes it shares power until it reaches an equilibrium
    08-08-2016 12:43 AM
  4. vientiane's Avatar
    Auto Restart
    A great idea.
    These options are already in SM-G935U (S7 edge US unlocked version)
    08-08-2016 01:22 AM
  5. longy003's Avatar
    Also on my Note 5
    08-08-2016 02:18 AM
  6. anon(5719825)'s Avatar
    I noticed the last time when I connected both of my S7 Edge phones to transfer something between the two using Smart Switch that the batterie indicators showed they were charging and same with my Note 5. It's nothing new.
    08-08-2016 03:00 AM
  7. boufa's Avatar
    Also on my Note 5
    Not my AT&T note 5
    New is in the eye of the beholder. An extremely small number of people have the s7 edge and are considering or will get a Note 7.... so for the 99.9999% of us who don't have an s7 device, its new.
    08-08-2016 07:33 AM
  1. Where is the contest widget for the Galaxy Note 7 contest?
    Last Post: 08-09-2016, 09:37 PM
  2. Does the note 7 at least feel more like a note than an edge?
    By Savatage79 in forum Samsung Galaxy Note 7
    Last Post: 08-08-2016, 01:41 AM
  3. Question about the sd card that's bundled
    By atomicpower in forum Samsung Galaxy Note 7
    Last Post: 08-07-2016, 10:52 PM
  4. How to switch a thing from always to make it where I choose
    Last Post: 08-07-2016, 09:26 PM
  5. Where is the USB Option on the Optimus L90?
    Last Post: 08-07-2016, 09:14 PM
