09-28-2016 11:17 AM
36 12
tools
  1. dsignori's Avatar
    see nothing that suggests it works with apps
    That suggests <what> works with apps? Once you adjust the display resolution in the power saving mode, and turn on power saving, the display would remain at that level - for all apps - until you turn off power saving mode.
    Is this not what you meant? Why would this be a bad thing, this is great IMO
    08-09-2016 03:17 PM
  2. rushmore's Avatar
    Sorry, meant mainly games. Yes, as my OP suggests it is great. Googling and calling my local Verizon confirms that it works with all apps and the CPU can be increased to 100% or decreased to what you want. Now THAT is good CPU/GPU governor management
    This adjustment alone should be huge for battery life. Most apps do not need 1440p and simply drains battery and makes the device hot.
    Funny thing is the rep did not even know, but tested and was surprised you can tweak CPU, resolution and other stuff too. Impressive.
    This effort alone and keeping the 3.5MM jack makes me feel "compelled" to give Samsung my business again. Skipped them on the Note 5 due to no micro sd.
    Added: Also pushing 256GB micro cards for pre-orders. HUUUGE.
    dsignori likes this.
    08-09-2016 03:45 PM
  3. queenren's Avatar
    Use an iphone then go back to android. You'll notice the lag. I was just at best buy yesterday playing with the latest and greatest phones. Lag on all of them. I'm using my backup nexus 6 until the note 7 releases and it's horrible for lag. My wife's Galaxy S6, laggy. Even the new note 7 shows some slight lag in the store but it's better than any other android phone.
    I'm also hoping the signal strength is better on the note 7. My iphone can pull down strong wi-fi and LTE signals where my nexus 6 gets nothing. Even on a recent camping trip some friends had no signal on their Note 5's while I had a couple bars on my iphone.
    Which iphone/ipod touch? I'm comparing to a 6S plus. The older ones will show some lag.
    Hardware and software are the same. If one android phone has lag the same models all have lag. Perhaps some just don't notice it as much as others.
    There's pros and cons in all things.
    I am pretty minimal when it comes to apps. I keep an eye on battery and memory usage and any app using too much that i'm not actively using I uninstall. So my phones are kept pretty clean. I still get the lag.
    If you're running a beta build it can be. I was but reverted back. Otherwise it's super smooth with any app.
    I'm noticing a pattern with you. LOL. Hmmm...what could it be? LOL
    Anyway, I own both a 6s Plus and a S7E. Does the S7E stutter a bit? Yes, it does rarely. Whenever that happens, all I do is restart my phone and it's fixed. No issues.
    However, I will not say the the 6s Plus is the best thing since sliced bread, because it is NOT! iOS can be buggy as hell. Even with the new jailbreak that is out now, I am STILL not switching back to the iPhone as my daily driver because I am having too much fun with my S7E. I currently have 3 different launchers installed - all with different themes - and I switch between them when I feel like it. It's easy.
    And don't get me started on the pile of pooh called iTunes! I have lost so many playlists because of Apple Music, it's ridiculous! Talk about Apple being the best...they are NOT.
    The reason why you see no lag in the iPhone is because the iPhone is a smartphone compared the the S7E and the Note 7, which are literally mini computers in your pocket. You can't do much on your iPhone. File sharing alone is a huge PAIN on an iPhone.
    IMO, Samsung hit it out of the park with the S7E! After using an iPhone for the past year and a half, Samsung has made me a believer in Android again! And I am loving every minute!
    Whoa. Wow. Have been with iOS for like 5 years, is there really going to be a large lag tax I'll have to pay as compared to the iPhone? And that android phones get laggier with time.... If this is true I will reconsider my move back to Android. Please those of you who have moved to android from apple weigh in.
    Are you really going to reconsider because some person that you don't know posted something on the internet?
    The 6s plus is very lagy in the recent apps
    Thank you.
    08-09-2016 04:17 PM
  4. leolion399's Avatar
    I'm on the 6plus and their is no lag,just buttery smooth flow of content
    08-09-2016 05:06 PM
  5. ThrottleJohnny's Avatar
    I'm happy people love their iPhones. This is a Samsung Note thread.
    gogoplata1980 likes this.
    08-09-2016 05:10 PM
  6. rushmore's Avatar
    The N7 power setting tweaks are very flexible. Almost like someone worthy at XDA was consulted or something. If you just want 1080p, you can pick that. The combination of options is cool. It is funny adjusting the display res and watching the battery estimate jump up two hours. All the tweaks have battery estimates and apparently refine with use.
    I will probably leave in 1080p unless web browsing or using Gear VR.
    08-09-2016 07:36 PM
  7. naminenam's Avatar
    is the hdr hardware or software i have not found a person to tell me if it is or if it isn't hardware
    09-27-2016 05:37 PM
  8. jamesrick80's Avatar
    It's hardware and software......
    Samsung meant that the new phablet is actually able to play HDR video content on the screen, like its newest, more expensive TV sets do. Streaming and showing HDR video requires special calibration and processing power, so Samsung outfitted the Note 7 with a mobile version of its DNIe processing chips, borrowed directly from its expensive 4K TV sets that can play HDR.
    The handset covers the basic HDR10 standard rather than the more demanding and confusing Dolby Vision standard, which requires end-to-end HDR processing. Thus, as far as base conditions go, the Note 7 should fit in the requirement for 540+ nits of peak brightness and black levels less than 0.0005 nits, having an OLED display and all, similar to the way Samsung's TVs are made to fit the HDR10 video standard.
    Source:
    http://www.phonearena.com/news/Note-...ovides_id83814
    09-27-2016 08:11 PM
  9. naminenam's Avatar
    so that mean if it isnt just software there no hope for my s7 edge on getting hdr
    09-27-2016 11:38 PM
  10. msm0511's Avatar
    Here's an article with what shows/movies on Netflix, Amazon etc. stream using HDR 10.
    Where and how to watch HDR content on the Note 7
    There could be more content now b/c this article is 5 weeks old. I watched a little Man in the High Castle, and it looks pretty amazing!
    09-28-2016 09:57 AM
  11. rushmore's Avatar
    Yes, but the will not stop somebody from selling an app for that
    09-28-2016 11:17 AM
36 12
  1. Replies: 8
    Last Post: 08-09-2016, 06:43 PM
  2. I can't search for a contact and then edit it?
    Last Post: 08-09-2016, 06:30 PM
  3. Replies: 1
    Last Post: 08-09-2016, 12:14 PM
  4. Replies: 2
    Last Post: 08-09-2016, 10:01 AM
  5. Will best buy price match targets $100 gift card for Note 7 pre order?
    By Halloweenoreo in forum Samsung Galaxy Note 7
    Last Post: 08-09-2016, 09:56 AM
