08-14-2016 10:44 PM
57 123
tools
  1. Gsxr151's Avatar
    someone tested the battery life on reddit . https://www.reddit.com/r/Android/com...sults_updated/
    You rock!! Thanks for sharing, I will check it out.
    08-14-2016 12:43 PM
  2. dsignori's Avatar
    This sounds like good news. We will see once we all have them, but this sounds like good performance.
    08-14-2016 06:11 PM
  3. EMGSM's Avatar
    I refuse to believe a 100 mah difference equates to an hour.
    Yeah I don't think so either
    PlaybookFanatic likes this.
    08-14-2016 08:38 PM
  4. Clocks's Avatar
    TLDR: 24 hours off charger / 6 hours screen on time / 8% battery remaining.
    Gsxr151 likes this.
    08-14-2016 10:40 PM
  5. Gsxr151's Avatar
    It is a different type of battery than the S7 Edge.
    08-14-2016 10:43 PM
  6. PlaybookFanatic's Avatar
    It doesn't. Assuming 6 hours SOT m normal usage on the Note 5, each 100 mAh should be approximately 12 minutes of SOT. And since we all know to avoid getting the battery below 40%, it's likely closer to a 5-7 minute difference, all other things being equal.
    Not below 40? 😨
    08-14-2016 10:43 PM
  7. PlaybookFanatic's Avatar
    It just doesn't add up.
    08-14-2016 10:44 PM
57 123
  1. How to upgrade Coolpad 3300A to Marshmallow?
    By 69Rixter in forum General Help and How To
    Last Post: 09-08-2016, 10:36 PM
  2. Are Note Edge users under impressed with the Note 7?
    By Leetemp in forum Samsung Galaxy Note 7
    Last Post: 08-10-2016, 11:31 AM
  3. Galaxy note 7 display beats s7, takes top spot
    By Torm558 in forum Samsung Galaxy Note 7
    Last Post: 08-09-2016, 02:31 PM
  4. Where do I insert the SD card in Samsung Note 5?
    Last Post: 08-09-2016, 12:05 PM
  5. Replies: 0
    Last Post: 08-09-2016, 11:57 AM
