1. shadow82x's Avatar
    Hi all,
    I have a few questions for those who had a chance to look at the Verizon branded Note 7.
    1 - Is Samsung Cloud a thing on these devices? Or has Verizon modified it so it only uses their own clouds service?
    2 - Are all the same battery save + optimization features on the device as seen during the hands on videos?
    3 - Will this phone work on any carrier? ie Unlocked if I want to go to t-mobile down the road?
    Thanks
    08-11-2016 03:03 PM
  2. Joe the Insider's Avatar
    Yes, Yes and absolutely.
    08-11-2016 03:23 PM
  3. shadow82x's Avatar
    Thanks Joe. For the first one, what does the yes apply to? Samsung Cloud is still on these devices?
    Cheers
    08-11-2016 03:24 PM
  4. dsignori's Avatar
    - Yes
    - Yes
    - <correction> Yes !
    08-11-2016 03:49 PM
  5. d2r2's Avatar
    Verizon android devices are already unlocked for gsm network use. My wife had s5 for verizon she deicded to go with tmobile. All i had to do was set the apn setting for tmobile and worked like a charm.
    dsignori likes this.
    08-11-2016 04:37 PM
  6. shadow82x's Avatar
    So yes it looks like Samsung Cloud might be missing, and for some odd reason it's not using the new settings layout? Ugh, Verizon.
    08-13-2016 12:20 AM
  7. Almeuit's Avatar
    - Yes
    - Yes
    - You'll need to get VZW to unlock it first
    This phone will be unlocked on Verizon. Pretty much all LTE phones from them that are new are unlocked out of the gate.
    08-13-2016 03:15 AM
  8. dsignori's Avatar
    Awesome. Good to know!
    08-13-2016 11:32 AM
  9. dpham00's Avatar
    While it will work with tmobile, Verizon's website doesn't list tmobile lte band 12 or 4g aws.
    I am also not sure about features like wfc and volte.
    08-13-2016 01:10 PM
  1. Note 7 vs iPhone 6s Speedtest
    By MarqBland in forum Samsung Galaxy Note 7
    Last Post: 08-13-2016, 10:40 PM
  2. Replies: 6
    Last Post: 08-13-2016, 07:13 PM
  3. Last giveaway: Win a Note 7 from Android Central!
    By Sara Agai in forum Ask a Question
    Last Post: 08-12-2016, 07:53 AM
  4. Note 7 Delayed in Malaysia
    By delynnie in forum Samsung Galaxy Note 7
    Last Post: 08-11-2016, 02:49 PM
  5. note 7 cooling
    By nonie in forum Samsung Galaxy Note 7
    Last Post: 08-11-2016, 01:16 PM
