09-13-2016 10:38 PM
41 12
tools
  1. noteiii007's Avatar
    Anyone finding it runs very warm to hot even after setting and syncing it?
    Also find thst it doesn't fast charge with Supplied cable and USB fast charge Plug.
    Angelique Agee likes this.
    08-18-2016 05:48 PM
  2. elvyb's Avatar
    Mine running great.
    Not hot or slow.
    olliedawn likes this.
    08-18-2016 05:57 PM
  3. haganjeff's Avatar
    Mine shows that it is fast charging with supplied cord. Shows 46 minutes to a full charge from 65%. It did get hot after the Smart Switch, but cooled down after all the apps were installed.
    gohangel likes this.
    08-18-2016 05:59 PM
  4. jv1218's Avatar
    Dang more! Apart from the gorilla glass 5 Being able to scratch easily, overheating issues too I'm feeling some buyers remorse!
    08-18-2016 06:04 PM
  5. felloffthetruck's Avatar
    Most new galaxy phones always get hot when first setting them up. Should get better after some use.
    08-18-2016 06:05 PM
  6. badMojo69's Avatar
    Mine is so hot I made smores! Mmmmmmmm
    POS phone
    08-18-2016 06:08 PM
  7. ThrottleJohnny's Avatar
    This.
    But people are going to ignore your post. They don't want to admit this phone is just fine.
    PlaybookFanatic likes this.
    08-18-2016 06:15 PM
  8. ibcop's Avatar
    With the fast charge, the less battery the faster the charge. More battery? Slower charge.
    08-18-2016 06:23 PM
  9. boufa's Avatar
    Ppl are going to ignore this post. They don't want to believe that the note is already bad
    I do believe that A note could be bad. I don't take 1 report and extrapolate it to the entire line. Far, far too many variables to blame the device on 1 reported "issue"
    08-18-2016 06:26 PM
  10. msm0511's Avatar
    I charged mine completely before turning it on and set up as new. I haven't put it back on the charger to test the speed, but mine hasn't really gotten hot. It did get pretty warm when I was walking my dog, but all my phones do that in the hot GA sun.
    08-18-2016 06:33 PM
  11. Averix's Avatar
    Do you just lurk to post negative things on Samsung phones? I realize you're a Nexus fan, but please don't just attack a phone you have no intention of ever owning. Thanks.
    08-18-2016 07:05 PM
  12. dpham00's Avatar
    What temperature has the battery and cpu reached?
    08-19-2016 12:05 AM
  13. dsignori's Avatar
    Mine has no issues so far. Fast-charges, and was not hot (outside of me downloading 75 apps in 30 minutes :-)
    08-19-2016 01:08 AM
  14. catloverplayer's Avatar
    If it's like the Note 5 getting hot when charging is normal and nothing to worry about. Also it will get hotter if it's in a case while charging.
    My Note 5 specifically mentions in the settings fast charge will cause the phone to get hot so I'd expect the same with 7.
    08-19-2016 03:30 AM
  15. Tazgrl0x's Avatar
    Mine is doing the same thing.
    08-19-2016 06:26 PM
  16. PraetorianGuard14's Avatar
    I think this usually happens with new phones. Give it a few days?
    08-19-2016 06:27 PM
  17. Angelique Agee's Avatar
    08-20-2016 08:17 AM
  18. Angelique Agee's Avatar
    Running hot and slow battery charge..
    08-20-2016 08:19 AM
  19. svtalex's Avatar
    Don't know if ur coming from the note 5. But remember this does have a bigger battery. So it will take longer.
    08-20-2016 08:29 AM
  20. Angelique Agee's Avatar
    Yes I am having these initial issues as well. Paid way too much for this phone to have problems. How do we fix?
    08-20-2016 08:47 AM
  21. ScottJ28's Avatar
    Got hot with the initial smart sync, but cooled down quickly and no problems with fast charge. Running great so far.
    08-20-2016 10:01 AM
  22. DoyouFanBoyBro's Avatar
    Guys the charger it comes with is NOT usb C 3.0.
    I bought a 3.0 charger AND cables and it's blazing fast charge.
    My note does get hot thought in use. Just making a comment about the charging.
    08-20-2016 10:08 AM
  23. ScottsoNJ's Avatar
    Some Samsung phones get hot. Some Nexus phones bend lol
    08-20-2016 10:39 AM
  24. coolbreeze78's Avatar
    I love these day one complaints. Yes the phone gets hot, stutters and lags at first. It's caching and reading/writing a ton of data in the background. Check back in 3 days, minimum after things settle.
    And the charging is most certainly fast. I went from 1% to 100% in 1 hr 42 minutes yesterday. That's fine by me.
    So yeah, time is what you need for it to calm down and operate well going forward. But by all means, buy another brand if you like. It'll do it as well the first day or two.
    08-20-2016 10:42 AM
  25. my6one's Avatar
    I've had my Note 7 for 2 days and it charges slow and runs hot when charging. I'm not a happy guy since I had great expectations and paid $800 for the new Note 7.
    08-21-2016 09:59 PM
41 12
  1. Replies: 2
    Last Post: 09-07-2016, 11:52 AM
  2. Replies: 1
    Last Post: 08-19-2016, 03:03 AM
  3. Replies: 1
    Last Post: 08-19-2016, 02:53 AM
  4. Replies: 1
    Last Post: 08-18-2016, 05:01 PM
  5. Why have my videos slowed on htc desire 62
    Last Post: 08-18-2016, 04:13 PM
