01-30-2017 04:13 PM
37 12
tools
  1. freeideasguy's Avatar
    Hi all. Switched to Samsung from Apple. This is amazing!
    I got the phone yesterday (T-Mobile) and also a Gear Fit 2. I've trying everything but notification on the tracker from the phone don't seem to work. Everything is on under settings but still is not working.
    Anyone has the same issue?
    Big thanks!
    08-19-2016 01:36 PM
  2. dsignori's Avatar
    Welcome to Android. I think you'll love it.
    Have you installed the Samsung Gear app on your phone, then used that to set the watch up?
    CNET details the process here if you need more. Good luck.
    08-19-2016 02:06 PM
  3. freeideasguy's Avatar
    Yes of course i have, an have enabled notifications etc.
    08-19-2016 02:10 PM
  4. dsignori's Avatar
    OK, so under the "Manage Notifications" section, they are all selected I assume, right?
    08-19-2016 02:14 PM
  5. freeideasguy's Avatar
    yes. either all or selected.
    08-19-2016 02:17 PM
  6. dsignori's Avatar
    Not sure what it might be then honestly. Hopefully others might chime in with solutions.
    If it were me, first I'd unpair/repair with the phone. If no luck, then factory reset the Gear Fit2. If still no luck I would look to exchange it.
    08-19-2016 02:19 PM
  7. freeideasguy's Avatar
    Thanks. I just read somewhere an update disabled their notifications. Will lookn into it more.
    08-19-2016 02:22 PM
  8. Gdwheel's Avatar
    Are you getting notifications on the phone? It only sends the notifications to the Gear if the phone is getting them? Just another idea. I don't have the Gear Fit 2, so I don't know specifically.
    08-19-2016 02:25 PM
  9. freeideasguy's Avatar
    Yes, of course I get notifications on the phone :/
    08-19-2016 02:32 PM
  10. freeideasguy's Avatar
    Anyone, anything? it's very frustrating!
    08-19-2016 03:58 PM
  11. Clocks's Avatar
    There is a setting to only show gear fit2 notifications when your phone is not in use. Check that out?
    08-19-2016 04:22 PM
  12. freeideasguy's Avatar
    Tried both. unfortunately nothing
    08-19-2016 04:58 PM
  13. freeideasguy's Avatar
    This is so frustrating.
    08-19-2016 06:27 PM
  14. chris31876's Avatar
    I have been bothered by this for the most part of today as well. I was about to give up i had actually taken the watch off and then i noticed there is a white sticker on the bottom of the watch. I peeled it off then tested again and it works perfect. Wow i feel like an *****. I guess that sticker blocked the sensor and was detecting that it was on my wrist. Not sure if this is whats wrong with you but its what was with me.
    Gdwheel and Strong_Genetics like this.
    08-19-2016 07:13 PM
  15. Pippinsky's Avatar
    Apple usually just works. I sense your frustration.
    08-19-2016 07:19 PM
  16. slackerjack's Avatar
    Yeah peeling the sticker helps
    08-19-2016 07:26 PM
  17. chris31876's Avatar
    yea i know was just trying to help. ITs what was wrong with my feel like an ***** not checking that one.
    slackerjack likes this.
    08-19-2016 07:40 PM
  18. freeideasguy's Avatar
    Actually that was it! my god. You must change your nickname to lifesaver. I use tech products for years, somehow just didn't see it! Damn man! Thank you thank you so much...
    08-19-2016 10:03 PM
  19. angiebugg's Avatar
    OMGGG!!!!! Thank you sooo much for this - I feel the same - now it is working....that was soooo odd....
    I knew I had all of the settings right too, but just wasn't getting the notis - ***whew****
    08-20-2016 09:56 PM
  20. Torm558's Avatar
    Out of curiosity, is the gear fit 2 watches coming in black or the grey showing in the promo pics? Didn't get an option to choose a color
    08-21-2016 04:06 AM
  21. angiebugg's Avatar
    Black and it is a lighter black. almost charcoal grey. There is also blue and pink - at best buy anyways.
    08-21-2016 11:38 AM
  22. convert's Avatar
    I already had the Gear Fit 2 so it's not one I got with the promotion (I'm waiting on a backordered SD card!) and it was working fine with my Note 3 but for some reason I am not getting any notifications on my Note 7. It worked like a champ until I switched phones and hard reset to it my Note 7. It's not a sticker issue-I pulled that off in the first place when I originally got it a couple months ago. I wonder if I need to reset and start from scratch but I have all the settings telling to accept notifications and I am not getting alerts to my watch when my phone rings nor text messages or anything. Before I factory reset, does anyone have any suggestions?
    08-23-2016 09:10 PM
  23. Oj467's Avatar
    I turned "Limit notifications" to off in the Gear app on my Note 7. Since upgrading from my Note 4 my regular email notifications stopped appearing on my Gear S2. Now that I've changed that it seems to have fixed that issue.
    Now if they'd just push out a fix to keep my watch from ringing when I get a call even though it's set to vibrate only. ><
    08-23-2016 09:53 PM
  24. convert's Avatar
    Yeah, I do have that turned off too. Thanks anyway. though. I wish I knew why it's not working. I just got a phone call and no notification. Looks like I will be factory resetting and trying again soon.
    08-23-2016 10:31 PM
  25. convert's Avatar
    I decided to reset my phone and that did the trick. All is well and I'm getting my notifications just fine now.
    08-24-2016 10:18 PM
37 12
  1. Replies: 1
    Last Post: 08-26-2016, 07:48 AM
  2. Badger stopped working how do I restart it
    Last Post: 08-26-2016, 05:53 AM
  3. Replies: 0
    Last Post: 08-19-2016, 01:28 PM
  4. Replies: 0
    Last Post: 08-19-2016, 01:27 PM
  5. GMail on phone not showing notifications (number of new mails)
    By SteelSteve in forum General Help and How To
    Last Post: 08-19-2016, 01:17 PM
