1. Strickster1's Avatar
    Does anyone notice a rattling sound when shaking the Note 7 ?
    08-19-2016 07:29 PM
  2. Carlo Villa's Avatar
    None what so ever
    08-19-2016 07:32 PM
  3. stackberry369's Avatar
    Why do you want to shake it? It's an $850 computer, not a bag of chip's.
    Jona005 and fsfty like this.
    08-19-2016 07:36 PM
  4. Strickster1's Avatar
    Certain features and apps use a slight shaking motion. Also, I mean slightly shaking. It comes from the camera area. I believe it to be the OIS mechanism. Hardly noticeable when I open the camera app. I just checked and my older s3 and s4 do the same thing.
    08-19-2016 07:41 PM
  5. shook187's Avatar
    I hear a slight rattle, I think it could be the home button or any of the side buttons... with that said I probably never shake it again and don't really care that it rattles. You have to put it against your ear to really hear it.
    08-19-2016 07:43 PM
  6. Strickster1's Avatar
    Open the camera app and see if that helps.
    08-19-2016 07:44 PM
  7. Strickster1's Avatar
    I can hear mine with my arm fully extended in front of me.
    08-19-2016 07:46 PM
  8. trunge19's Avatar
    It's the S pen
    08-19-2016 07:49 PM
  9. Strickster1's Avatar
    Mine is the camera. S pen is removed. I'm calling Verizon asap for an exchange.
    08-19-2016 07:51 PM
  10. scott5626's Avatar
    I've seen the ois cause the rattle in other phones.
    08-19-2016 08:25 PM
  11. andrew_ackley's Avatar
    That's perfectly normal. Every phone with ois does that!
    Strickster1 likes this.
    08-19-2016 08:26 PM
  12. andrew_ackley's Avatar
    That's how u know its the ois is by opening the camera app it goes away.
    08-19-2016 08:27 PM
  1. Verizon has apparently gimped their Note 7.
    By JoJoCal19 in forum Samsung Galaxy Note 7
    Last Post: 09-18-2016, 04:41 PM
  2. Cell connection weak on Note... Again
    By spasell in forum Samsung Galaxy Note 7
    Last Post: 08-20-2016, 01:05 PM
  3. Integrating Samsung Notes with Evernote?
    By kpantz in forum Samsung Galaxy Note 7
    Last Post: 08-19-2016, 11:50 PM
  4. ATT Note 7 IMEI not found
    By Shattereddata in forum Samsung Galaxy Note 7
    Last Post: 08-19-2016, 09:56 PM
  5. Note 7 icons?
    By mikkelrev69 in forum Samsung Galaxy Note 7
    Last Post: 08-19-2016, 06:12 PM
