1. johnbody's Avatar
    Right under the bezel where the screen curves seems to show light bleeding through and it seems like the phone display is not all of the way down. Maybe I'm crazy and this is normal. To test this out your display on a white screen and look at it from the side under the edge bezel...
    08-20-2016 01:18 AM
  2. Jewels81's Avatar
    http://i68.tinypic.com/2iq9u.jpg
    I don't think it's a defect. I think it's probably meant to be like that. Mine is like that. I like that glow look. But let's see if other's have it.
    08-20-2016 01:23 AM
  3. Viscomi4444's Avatar
    I have it as well. This phone seems like its very well built so im not worried.
    Jewels81 likes this.
    08-20-2016 01:28 AM
  4. 05GT's Avatar
    I have it on my N7 as well as my previous S6E and S7E.
    08-20-2016 01:33 AM
  5. Jewels81's Avatar
    Thanks for reminding me lol I forget to mention my fiance s6 edge plus had this as well
    08-20-2016 01:44 AM
  6. boss.king's Avatar
    It's not a defect, it's light reflecting internally off the curved glass and onto the bezel where it meets the glass. There's no backlight because it's and AMOLED, so there's no backlight to leak. There are conspiracy theorists on Reddit acting like it's a massive defect being covered up but don't listen to them.
    05GT likes this.
    08-20-2016 01:52 AM
  7. Victor Hernandez Jr's Avatar
    My phone came with a scratch on the screen and as well a scratch on the SIM card tray
    08-20-2016 03:23 AM
  8. 05GT's Avatar
    How bad? You can always just return or swap it out.
    08-20-2016 12:29 PM
  9. tinybfk's Avatar
    Normal.
    08-20-2016 03:06 PM
  10. wricu01's Avatar
    Thats normal my S7 edge the same way
    08-20-2016 06:22 PM
  1. Note 7 will not hook up to wifi
    Last Post: 08-26-2016, 07:51 AM
  2. Trouble saving on SD card for Moto G 2nd Gen
    By BJL321 in forum Moto G (2014)
    Last Post: 08-22-2016, 03:30 PM
  3. Can I transfer everything from my iPhone 6 Plus to my Note 7
    By Jean Sagarese in forum Samsung Galaxy Note 7
    Last Post: 08-20-2016, 09:31 PM
  4. Replies: 0
    Last Post: 08-20-2016, 01:04 AM
  5. Temperature on AOD
    By jackal24 in forum Samsung Galaxy Note 7
    Last Post: 08-20-2016, 01:00 AM
