1. recDNA's Avatar
    I love to be able to check the battery % of my note 3 from my gear 2 watch using a samsung store app called air toggles. It also allowed me to put phone in vibrate mode from watch.
    Air toggles is no longer in samsung app store for note 7..
    Please please please can anyone find an app that will tell me note 7 battery % from gear 2 phone? That way as battery gets very low I can check level without turning on screen.
    Any samsung store gear app that will tell me this? I've looked and looked. Air toggles was so great. Wish they left it on tye store.
    Also.. Is the an app in samsung store for gear to lock phone screen from watch?
    Finally an app to put phone in vibration mode from watch?
    I would really really appreciate your help.
    Thanks. So much.
    08-20-2016 01:48 AM
  2. PlaybookFanatic's Avatar
    Just Smart Switch the app over from the old phone. It will make a copy of the app on your phone. It works for Glappy Bird.
    08-20-2016 01:51 AM
  3. recDNA's Avatar
    i did and it is but now how do I get it to watch. in samsung store a bar comes up to transfer to gear. since not in store no way inknow to get it in gear
    08-20-2016 01:58 AM
  4. PlaybookFanatic's Avatar
    Oh yeah. Maybe you could side load? I'm not sure how to dance around the part of the actual watch. Good question. Thanks for reminding me that I have to reset my S2.
    08-20-2016 02:07 AM
  5. recDNA's Avatar
    no idea how to sideload unrooted gear 2.maybe someone can help or find another app to do it?
    08-20-2016 02:09 AM
  6. recDNA's Avatar
    Is there a samsung gear app that shows note 7 battery percentage?Commander is an app that shows an icon but it is tiny and it just has 5 bars no actual percentage. I like seeing phone battery % from my watch.
    08-23-2016 09:14 AM
  7. dpham00's Avatar
    The all in one watch face supports phone battery level on the gear s2. It is a featured watch face. You need to download a rider app from the play store for phone battery(link is in the watch face description) . I prefer the all in one carbon myself, which also supports phone battery level.
    App Allowing Gear 2 to show Note 7 battery %-uploadfromtaptalk1471962090947.jpg
    08-23-2016 09:23 AM
  8. recDNA's Avatar
    Thanks but I like the weather watch face & I actually have a gear 2. I would just like an app I could open to show it. Maybe some toggles with it for wifi on off etc. Thanks again though. Nice watchface
    08-23-2016 09:29 AM
  9. recDNA's Avatar
    Finally solve the problem with a Widgets app
    08-27-2016 04:58 PM
  10. Rails Ruby's Avatar
    And what the Widgets App is called?
    01-05-2017 04:57 AM
  11. recDNA's Avatar
    Wearable widgets. Must be installed from samsung gear store and from playstore
    01-05-2017 07:23 AM
  12. pduffer's Avatar
    I use Quick Settings app on my Gear 2 Neo to control ringer, vibrate, etc. on my Note. (4, 7, 5 versions so far)
    01-06-2017 08:06 AM
  13. recDNA's Avatar
    I do too but it doesn't show battery %
    05-02-2019 03:26 PM
  1. 60+ Samsung Galaxy Note 7 Tips & Tricks
    By dabombcra in forum Samsung Galaxy Note 7
    Last Post: 08-20-2016, 06:24 AM
  2. Note 7 Case
    By drrobg in forum Samsung Galaxy Note 7
    Last Post: 08-20-2016, 02:07 AM
  3. Blurry apps?
    By bacano22 in forum Samsung Galaxy Note 7
    Last Post: 08-20-2016, 01:39 AM
  4. how to fix wifi and bluetooth on sony xperia ray?
    Last Post: 08-20-2016, 01:05 AM
  5. Replies: 0
    Last Post: 08-20-2016, 12:55 AM
