1. magicrobots's Avatar
    Last night I plugged my phone into my car, and a little dialogue came up which asked me to choose a connection type; data, backup, power, some other stuff I don't remember. I chose power because I wanted it to charge.
    Then I tried playing some music over the media connection but the car said nothing was plugged into the USB cable. Clearly that was baloney. I am assuming that the setting I selected in that original dialogue I got when I plugged the phone in would help with this problem but I can't for the life of me find it to make the change.
    Any help would be greatly appreciated, thanks a lot!
    08-20-2016 03:37 PM
  2. papabutter's Avatar
    Developer settings
    08-20-2016 03:43 PM
  3. papabutter's Avatar
    Right here
    08-20-2016 03:54 PM
  4. magicrobots's Avatar
    Thanks! Not seeing the attachment on mobile forum, I'll check when I get home. Thanks again.
    08-20-2016 05:24 PM
  5. magicrobots's Avatar
    I was finally able to look into this today, thanks for your suggestion. Sadly the best I can get from any of those developer settings is the list of downloaded ringtones I have playing through the car while Google music plays on my phone. Not exactly the result I was hoping for!
    Trying to get it so when plugged in, all phone audio is routed through the is usb so music, navigation, etc come through the car audio. Is this even possible?
    Coming from iPhone where this was the default behaviour.
    Thanks again for any suggestions!
    08-21-2016 04:57 PM
  6. dsignori's Avatar
    I'll preface this with the fact that I do not know much about this so maybe others can chime in that have more specific knowledge. I guess it depends on your car, but for me a regular USB connection to the car will not output my audio through it. I tried all methods of USB connection (MTP and others) with no luck. My car does natively support my iPod Touch audio though a USB connection oddly, but not Android phones. If it won't work for you, and if no one else has better suggestions, you might want to consider using either:
    A) Bluetooth Audio to your car - if your car supports it
    B) The 3.5mm headphone jack to output audio - if your car has a 3.5mm input.
    08-21-2016 05:14 PM
  7. magicrobots's Avatar
    Sigh.
    The 3.5mm jack has pretty crappy quality compared to the USB connection but I guess it's better than nothing.
    I have the phone hooked up properly to the car via bluetooth but for some reason it doesn't recognize it as a media player; just for calls.
    Oh well. I guess this will be the only thing that will make me miss the iPhone. Not bad overall.
    08-21-2016 07:07 PM
  8. Kikoshi's Avatar
    Go into Bluetooth settings and look to see if your car has the Media Option setup.
    08-21-2016 07:58 PM
  9. magicrobots's Avatar
    I ended up buying this to fill in the technical void. We'll see if it works.
    https://www.amazon.com/gp/product/B00ED5SRWG/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
    08-22-2016 07:04 PM
  1. Note 7 Bluetooth will not connect to my car. Sad face.
    By magicrobots in forum Samsung Galaxy Note 7
    Last Post: 09-30-2016, 07:12 AM
  2. Nexus 7 USB Camera App
    By Thinker2 in forum Google Nexus 7 Tablet (2013)
    Last Post: 08-25-2016, 07:49 PM
  3. Got the new VR, how about you?
    By Xm_jdm in forum Samsung Galaxy Note 7 Cases & Accessories
    Last Post: 08-24-2016, 09:26 PM
  4. dumb question
    By nonie in forum Samsung Galaxy Note 7
    Last Post: 08-20-2016, 08:20 PM
  5. how do you set a photo for a contact on galaxy note 7
    Last Post: 08-20-2016, 02:16 PM
