1. billykac's Avatar
    I connected a micro USB OTG drive to an "approved" micro USB to USB-C adapter from Anker. Every time I plugged the duo into my N7, a notification appeared telling me I have moisture in the USB port.
    Somehow, the OTG/Anker adapter is non-compliant and presents like moisture in the USB port to the N7. My guess.
    Not a biggie, plenty of work-arounds.
    Just thought I'd share.
    08-20-2016 07:09 PM
  2. billykac's Avatar
    With further investigation, the Anker "approved" adapters work perfectly for charging.
    Maybe there is something funky with the pin-outs on my OTG drive that I plugged the adapter onto, causing the "Moisture in USB Port" notification. Users of the S7 see the same thing when using random 3rd party cables. Gotta be a pin-out incompatibility.
    We'll probably see more of this as N7 owners begin to buy more accessories to adapt to the USB-C port.
    08-21-2016 08:22 AM
  3. TX Jedi's Avatar
    i am having the EXACT same problem with the EXACT same adapter. Not a happy camper right now.
    08-24-2016 02:30 PM
  4. billykac's Avatar
    If you are referring to the Anker adapter (not the OTG drive) it's actually "fully approved" by Benson Leung. Benson has his approval write-up as the first review on Amazon. Since it works fine with my microUSB charger cables, I assumed it's the OTG drive that's the problem.
    What are you using the Anker adapter on?
    08-24-2016 02:46 PM
  5. TX Jedi's Avatar
    The Note 7. Trying to connect it to my PC. The PC has a hard time 'seeing' the phone. I can't open or transfer files from my phone.
    08-24-2016 03:43 PM
  6. Kermy's Avatar
    Happened to me too when I used an adapter to connect to an external dac/amp. Was worried I messed up something.
    08-24-2016 03:46 PM
  7. TX Jedi's Avatar
    I have notified Anker and the should be getting back to me sometime soon. I will update here when I find out something.
    08-25-2016 10:02 AM
  1. Does keylogger detect pattern
    By pretorian00 in forum Ask a Question
    Last Post: 08-21-2016, 09:25 PM
  2. How to resolve layout object/method references in ActivityMain.java
    By jonmelvin in forum Software Development and Hacking
    Last Post: 08-21-2016, 04:43 AM
  3. Replies: 1
    Last Post: 08-20-2016, 07:21 PM
  4. Replies: 1
    Last Post: 08-20-2016, 07:20 PM
  5. Why is my s4 not making sounds when calls or texts come in.
    Last Post: 08-20-2016, 06:50 PM
