09-13-2016 06:44 PM
601 ... 910111213 ...
tools
  1. spasell's Avatar
    Yep, I just got it Never really like the white backgrounds on settings and phone pad. White backgrounds are AMOLED's Kryptonite. Also too garish being all white background.
    BTW, weak LTE signal is a worse battery drain than the display set at 100%. Would be nice if there was an option to turn LTE off dynamically, if signal is a certain low threshold. That would be huge for battery life. You do not have to use an Android device in a weak signal area for it to drain.
    I think this is the biggest factor of battery drain..weak LTE signals. Whenever I am on the road traveling my battery is far better. When I am home, where Verizon is weaker, my battery is far worse.
    I agree that there should be some sort of option to fix this.
    08-24-2016 04:14 PM
  2. canonuevo's Avatar
    So what Screen on Time is everyone getting. I see people in XDA getting 6-7, I can barely get 4-5 with some disabled bloat.
    08-24-2016 04:17 PM
  3. Nilo7's Avatar
    The upper part of 4 hours right now. How long have you had it? In my experience with recent Samsung phones (S7E) and with what others are saying, the battery gets optimized after the first few days.
    08-24-2016 04:40 PM
  4. canonuevo's Avatar
    I've had the phone since Saturday. I'll give it another day or two.
    08-24-2016 04:46 PM
  5. Infamousx14's Avatar
    This is with 18% left on my phone with bunch of apps disabled, screen set to auto. So frustrating
    The Note 7 Battery life Thread-2.jpg.
    08-24-2016 05:33 PM
  6. Kelly Kearns's Avatar
    Do some of these percentages that Android System is using raise any alarms? They seem especially high, on mine, too. I remember a similar problem on the S7E and the fix was to disable the Knox setup wizard client, or something to that effect.
    A little. I've never had an Android phone that uses so much battery from Android System.
    They seem high to me. All my Samsung phones have been 4% to 7% for Android System and Android OS unless there was a problem. The first thing I would try was a cache wipe in recovery, if that didn't work, then a reset. I had one Note 5 that suddenly Android System started running high and nothing helped it.
    I finally sent it to Samsung but the problem continued after the repair and I just kept the TMO exchange handset.
    Laura Knotek likes this.
    08-24-2016 05:54 PM
  7. Nilo7's Avatar
    I'm definitely going to try disabling KNOX with Package Disabler Pro and see what happens tomorrow. I'll still get a little over 4 hours SOT today with it enabled, but the phone can do a lot more.
    08-24-2016 06:22 PM
  8. Zaku77's Avatar
    Mine today said that Android OS has used 20%. It's never showed that before. Has anyone figured out what that is yet?
    08-24-2016 06:57 PM
  9. xxaarraa's Avatar
    You guys must not have had the S7 or the S7E. Same story. I call it the "snapdragon tax"
    rushmore likes this.
    08-24-2016 07:16 PM
  10. Bartone's Avatar
    I had it at 100% at the exact same time yesterday and I haven't charged it since... I'm at 43%. I've been streaming videos, doing a bit of high graphic gaming (Dead Trigger), Facebook, texting, phone calls and such. I'm extremely impressed with the battery life I can easily last a day and a half on this battery... I'm using the snapdragon 820 variant.
    08-24-2016 07:27 PM
  11. Zaku77's Avatar
    This is my first Samsung phone. Has no one ever figured out what causes this or what to do about it?
    08-24-2016 07:33 PM
  12. spasell's Avatar
    So almost a week in and I am actually more impressed. With my Note 5 I was getting 8 or 9 hours with SOT of 3-3.5 on average. I'm a heavy user but not with videos or any gaming. Text Gmail news feeds. That's about it and then about 60-90 minutes of calls.
    On the N7 I am getting 9-10 hours with 4-4.5 hours of SOT. So an improvement.
    Granted my 6s+ I was getting 10-12 hours but don't know SOT usage as it isn't displayed. But I knew that coming in.
    08-24-2016 07:43 PM
  13. spasell's Avatar
    Here are my stats. SOT is 4 hours 27 min.
    08-24-2016 09:44 PM
  14. akin_t's Avatar
    Mixed bag for me. Took it off the charger at 10am, some light browsing; came home played mobius final fantasy for 4+ hours at highest performance.
    It's not great, but it's definitely worth it. I'm sure I could stretch it if I really wanted to.
    08-24-2016 10:19 PM
  15. akin_t's Avatar
    You can make the phone have 8 hours SoT if you really wanted to, but then you'll have to disable everything that makes the phone a Note.
    Not worth it imo.
    08-24-2016 10:22 PM
  16. TTQ225's Avatar
    Today is a day #1. It's been heavily used for 11.5 hours up to now with 6 hours remaining.
    08-24-2016 11:43 PM
  17. josh6113's Avatar
    Here is mine right now.This is day 2 with my note 7.
    08-24-2016 11:59 PM
  18. manni1to's Avatar
    This is what I'm at on my first charge. Can't say that I'm mad!!!
    08-25-2016 02:40 AM
  19. AhemThisGuy's Avatar
    08-25-2016 08:50 AM
  20. crystinonfire's Avatar
    Anyone using Nova getting this? I shouldn't put it to sleep, right?
    08-25-2016 11:40 AM
  21. Infamousx14's Avatar
    I just did cache wipe again. down to 50% battery and it says 100% android system usage ugh what should i do?
    08-25-2016 01:54 PM
  22. PorkPistol's Avatar
    https://uploads.tapatalk-cdn.com/2016...7d0a0f5a34.jpg
    That doesn't look right. Nova doesn't even show up for me on the battery usage area it's using that little.
    08-25-2016 02:04 PM
  23. Che Minati's Avatar
    Attachment 237128
    Good life so far i think..my s7 edge was slightly better but its Getting better..used package disabler pro and have on wifi Samsung pay iris scan on with youtube and pandora music goin on as well, usually.
    08-25-2016 02:19 PM
  24. crystinonfire's Avatar
    Ideas on how to fix it?
    08-25-2016 02:20 PM
  25. AhemThisGuy's Avatar
    Attachment 237128
    Getting pretty good battery here as well
    08-25-2016 02:23 PM
  1. Honor 5C: Too similar to the Honor 5X?
    By lumivalo in forum Honor 5C
    Last Post: 01-27-2017, 01:05 AM
  2. Replies: 10
    Last Post: 08-26-2016, 06:14 PM
  3. Sprint Note 5 unlocking
    By James Hogg in forum Sprint
    Last Post: 08-23-2016, 07:46 PM
  4. Replies: 0
    Last Post: 08-21-2016, 09:06 PM
  5. Replies: 0
    Last Post: 08-21-2016, 09:00 PM
