Save big + get 3 months free! Sign up for ExpressVPN today
09-13-2016 05:44 PM
601 ... 2122232425
tools
  1. tinybfk's Avatar
    09-04-2016 09:37 PM
  2. lions_lair99's Avatar
    Here's my LG stylo2 on battery saver. Read it and weep... and that was with iheart radio on the whole time and light to moderate use... I forgot to get a screen shot of the sot. The Note 7 Battery life Thread-capture-_2016-08-27-08-36-47.png
    09-04-2016 09:39 PM
  3. Steven Hadjez1's Avatar
    Today was a good battery day. I really hope things don't change with the recall exchange. I watched YouTube for a while this morning. Researched a bunch of stuff online, mainly guns. And went through some forums. 4 Gmail accounts set to push. Everything syncing. Bluetooth on and connected to a gear fit 2 all day. WiFi on the whole time and connected part of the time. NFC on. AOD on. Auto brightness. I'm on Sprint with the SD820 variant.
    Attachment 238483
    Here we go. Just when I was about to accept my 4 hours of sot with a smile, you have to do this to me. 7 hours?!!!!!!! How the heck is this possible? (by the way, it's a long time too. You're a pretty heavy user!)
    If only I could understand how you get this.....
    09-04-2016 09:59 PM
  4. Steven Hadjez1's Avatar
    Do you guys think the black theme helps with the battery? I just can't explain it!!! You literally get double the battery time than I get!
    09-04-2016 10:02 PM
  5. benjamminh's Avatar
    Dark themes are generally considered battery friendly for AMOLED screens.
    09-04-2016 11:07 PM
  6. tinybfk's Avatar
    I don't know why my battery life was so good yesterday. The only thing I didn't do was play games. I was to busy looking at other stuff and watching videos. My SOT has varied from just over 3 hours to what you see here. It never seems to be the same even with the he same general use. I didn't realize my SOT was so high yesterday until I noticed I hadn't even plugged it in while at work.
    09-05-2016 03:20 AM
  7. tinybfk's Avatar
    I think it helps a small amount. Not a ton since most apps still aren't dark and the videos I usually watch and games I play at times aren't affected by it. Mostly I just think it's easier on the eyes. Especially at night.
    09-05-2016 03:22 AM
  8. Steven Hadjez1's Avatar
    Well I'm curious to see how this evolves. If you could report back today after your day of use to compare?
    Maybe your battery gets better and better as you use your phone more and more? I've read somewhere that they function a bit like a muscle. The more you use them the stronger they get at the beginning.
    09-05-2016 06:44 AM
  9. Matt_james_matt's Avatar
    I cannot understand how you all are getting 4+ SOT. I have had the phone for a week now. It is very consistent, I get somewhere between 2.5 to 3 hours SOT with 20% remaining at the end of day. I am at least an hour off from you all. I have turned off WiFi Scanning, disabled some of the ATT bloat. Not using any power mgmt. profile yet.
    Any suggestion are very welcomed :-)
    I get 5 hours a minimum
    1st pic is not home so turning mobile data on and off throughout the day
    And the send pic is at home all day connected to wifi
    Attached Thumbnails The Note 7 Battery life Thread-1473089129194.jpg   The Note 7 Battery life Thread-1473089224644.jpg
    09-05-2016 10:27 AM
  10. Steven Hadjez1's Avatar
    You must have you luminosity very low. I keep mine around 75% and the power consumed by my screen is almost twice yours (usually between 1600 and 1800 mah by the time I have 1% battery left)...
    09-05-2016 11:49 AM
  11. Ca_lvn's Avatar
    Sprint just released a software update and part of it is improved battery life , although been pretty good for me multitasking, wifi calling is also part of the update
    09-05-2016 01:22 PM
  12. canonBoy's Avatar
    This isn't exactly a battery optimization note here, but I have come across this battery temp alarm app that might help a run away battery from getting too hot...
    https://play.google.com/store/apps/d...tterytempalarm
    09-05-2016 03:21 PM
  13. tinybfk's Avatar
    Here are today's stats so far. Less YouTube today but more Live Leak with chrome. Everything else was comparable.
    09-05-2016 06:10 PM
  14. spasell's Avatar
    So you can see my SOT was only 3 hours and I did charge for a whopping 10 min when I went to grocery store. I didn't even need to but force of habit.
    Damn good. Now if I was on it for 5 hours of SOT I'd probably be able to grab 12 hours total.
    I am also connected to Gear Fit 2 and wifi on, location on power saving.
    09-05-2016 06:34 PM
  15. Steven Hadjez1's Avatar
    UNBELIEVABLE..
    I just can't understand how it's possible .. I have half of your battery life.. And my Bluetooth is off.
    09-05-2016 09:19 PM
  16. Steven Hadjez1's Avatar
    The only way I can explain it is that you have you luminosity at 0% all day?!!!!
    Check out my sot. We both used 900 mah except you have over an hours of sot more than me... The Note 7 Battery life Thread-1473128454745.jpg
    09-05-2016 09:20 PM
  17. Steven Hadjez1's Avatar
    We never mention it enough, but besides the battery, fast charge is what can save us all. It makes us invincible....
    09-05-2016 09:23 PM
  18. spasell's Avatar
    Check out my sot. We both used 900 mah except you have over an hours of sot more than me... Click image for larger version.
    I keep it on auto brightness all day.
    Like I said it I didn't really do much with the phone for a lot of the day. Spent half the time I normally do on email and text. Wondering if because it's the weekend or Holiday for us if lack of emails being sent to me makes a difference as well.
    I only charged for 10 min which I think added 8% when I checked.
    No power saving either. I just wasnt picking it up as much as I normally do that day.
    09-06-2016 04:51 AM
  19. spasell's Avatar
    I'd like to help you but for some reason when using the app to read all of these I see this many times :
    09-06-2016 04:53 AM
  20. Gray Area's Avatar
    Good battery, hope my exchange will be as good or better! 100% battery gives me 6hr47min sot, usually I charge around 25% which I'm usually at 5hrs sot.
    The second pic is from last night where I finally was able to get less then 1% battery usage per hr overnight.
    09-06-2016 05:55 AM
  21. Gray Area's Avatar
    09-06-2016 05:56 AM
  22. Matt_james_matt's Avatar
    Mines usually always above half way sometime throughout the day I put it auto and at night I put it pretty low
    09-06-2016 06:57 AM
  23. rushmore's Avatar
    The Note 7 does not seem to have very good data radio reception. This is why I think there are big deltas with people comparing to their past devices and also seeing disparities one day to the next with the Note 7. If you are in a strong network area (at least four bars), very good battery life. Three bars or less and the battery drains.
    Yep, I know dBm signal is the measure, but three bars or less correlates to -100 or more plus dBm.
    My recent previous device radio signal rankings from best to worst:
    1. Razr Maxx
    2. MXPE
    3. Note 4
    4. Note 7 (about 5 dBm less than the Note 4).
    jamesrick80 likes this.
    09-06-2016 07:50 AM
  24. Dennis Piccioni's Avatar
    75%? Is this outdoors? Indoors that's gonna burn out my corneas! ;-)
    I keep it on Auto, but I make minor adjustments as needed. That means it's usually around 30% indoors and 100% outdoors.
    09-06-2016 08:17 AM
  25. ELAkid's Avatar
    This is my battery life it's been really good so far.
    09-06-2016 09:55 AM
601 ... 2122232425
  1. Honor 5C: Too similar to the Honor 5X?
    By lumivalo in forum Honor 5C
    Last Post: 01-27-2017, 12:05 AM
  2. Replies: 10
    Last Post: 08-26-2016, 05:14 PM
  3. Sprint Note 5 unlocking
    By James Hogg in forum General Carrier Discussion
    Last Post: 08-23-2016, 06:46 PM
  4. Replies: 0
    Last Post: 08-21-2016, 08:06 PM
  5. Replies: 0
    Last Post: 08-21-2016, 08:00 PM
