09-13-2016 06:44 PM
601 ... 22232425
tools
  1. rushmore's Avatar
    UNBELIEVABLE..
    I just can't understand how it's possible .. I have half of your battery life.. And my Bluetooth is off.
    How is the LTE signal where you are at when using? Weak LTE signal while using data can drain more battery than a display on 100% brightness. Even just background data usage the drain is significant, but not as much as a display.
    09-06-2016 11:05 AM
  2. Steven Hadjez1's Avatar
    Below the screenshots of my sim card status. I'm using a dual sim version of the phone. Half the time on wifi half the time 4g. I don't know if it has an impact but at the moment both the sim cards in my phone are roaming since I'm travelling.
    Anyway, I'm incapable of interpreting this data. Does this look fine to you? I took the measurement in the place in my house with the worst signal. But you can see that between the two screenshot the signal changes a lot.
    The Note 7 Battery life Thread-1473175318597.jpgThe Note 7 Battery life Thread-1473175322834.jpg
    09-06-2016 11:22 AM
  3. Steven Hadjez1's Avatar
    I'd like to help you but for some reason when using the app to read all of these I see this many times :
    https://uploads.tapatalk-cdn.com/2016...dddbbdae2b.jpg
    Weird! Maybe try from a laptop? Anyone else having trouble seeing my posts?
    09-06-2016 12:20 PM
  4. rushmore's Avatar
ID:	238639Click image for larger version.
    Only real way to quantify is comparing with your previous device. If those numbers match your previous device, no harm no foul for you
    09-06-2016 12:26 PM
  5. anon(782252)'s Avatar
    It's a shame that this device will be exchanged at some point when T-Mobile gets them in. The Note 7 Battery life Thread-1473181762524.jpgThe Note 7 Battery life Thread-1473181771553.jpgThe Note 7 Battery life Thread-1473181778183.jpg
    09-06-2016 01:09 PM
  6. souffoue's Avatar
    For some reason my battery life is draining fast and charging takes forever. When I got to work my battery was at 100%, that was about 5 hours ago. I haven't used my phone at all except for one, 2 minute phone call and the battery is now at 47%?? What is up with that?? Also, I noticed last night it took forever to charge (I have a wireless charger and have the phone set up for fast charge - or whatever it is called). Any thoughts? TIA!
    09-06-2016 03:55 PM
  7. canonuevo's Avatar
    It would help if you gave a screenshot of your battery usage. You can also try a factory data reset.
    benjamminh likes this.
    09-06-2016 04:42 PM
  8. Steven Hadjez1's Avatar
    It's a shame that this device will be exchanged at some point when T-Mobile gets them in. Click image for larger version.
ID:	238651Click image for larger version.
ID:	238652Click image for larger version.
    You're battery is miraculous. Mine lasts half the time.
    09-06-2016 06:27 PM
  9. anon(782252)'s Avatar
    Trust me, it hasn't been all roses. When Android system decides to run wild, I'm lucky to get half that.
    However, I've either figured something out or just been lucky 4 days in a row but when I charge the phone to 100% , the first thing I do after taking it off the charger is restart the phone. Since I started doing that, I haven't had a single problem with Android system.
    09-06-2016 06:32 PM
  10. Steven Hadjez1's Avatar
    Thanks for the tip. I'll try it as well and report to you...
    I'm in the plane right now, 8 hours flight browsing from go-go in-flight but with my phone on airplane mode. My 4g definitely drains my battery. Cause right now without it it's a beast!!!
    09-06-2016 09:19 PM
  11. Steven Hadjez1's Avatar
    Looks to me like this new iPhone might have a battery as good as my note 7. I think I'll change.
    09-08-2016 01:46 AM
  12. Dukins's Avatar
    Same thing for me. It's a shame we have to restart the phone to have decent screen on time.
    09-08-2016 10:25 AM
  13. Ca_lvn's Avatar
    I got a notification last night that one app was hogging the battery asked me if I wanted to disable ,then showed me battery time left pretty cool
    09-08-2016 12:00 PM
  14. ELAkid's Avatar
    Something strange did happen with my note 7 for the first time Early this morning I went to charge it and like and hour in a half later it was still at below 50% so I turned the phone off and it charged up quickly like it normally does
    09-08-2016 12:24 PM
  15. anon(782252)'s Avatar
    Yeah, Android system does weird things sometimes but the simple 1 minute inconvenience is working. I'm either at 5 or 6 full charges then reboot in a row with no excessive Android system drain. On this charge I'm still at 23%, 19.5 hours up, 4.5 hours SOT.
    09-08-2016 12:52 PM
  16. Android Optimizer's Avatar
    It could be a problematic app that is constantly running in the background (see what it says on your phone is the App power monitor area that is shown in the post above yours). Your phone could be continually waking up where ever you are keeping it (ex: pocket). You should also try running it in max power saving mode and see how long it lasts you. My phone running in max power saving mode has an estimated battery life of five and a half days.
    09-08-2016 01:01 PM
  17. Steven Hadjez1's Avatar
    Just checked my wife's iPhone 6 plus for comparaison (not the S but the two year old model)! She doesn't have any battery optimizing features turned on. She just plugged it in for 20 minutes during the day. Everything is on.
    She gets double the sot of my note 7. Triple the on battery time. I think that says it all about what is about to become the best battery on the market very soon. Hint: it came out yesterday, and now comes in jet black. P.s. I'm a Samsung fan.
    09-08-2016 04:25 PM
  18. lions_lair99's Avatar
    Lg stylo2
    That's not that hard to match or beat. Notice there's 4hrs left at 5hrs screen time.
    The Note 7 Battery life Thread-capture-_2016-09-06-22-53-45.pngThe Note 7 Battery life Thread-capture-_2016-09-06-22-54-02.pngThe Note 7 Battery life Thread-capture-_2016-09-06-22-54-20.pngThe Note 7 Battery life Thread-capture-_2016-09-06-22-54-32.pngThe Note 7 Battery life Thread-capture-_2016-09-06-22-54-39.png
    09-08-2016 04:50 PM
  19. celsior360's Avatar
    Does anyone know if N7 support qualcomm quick charge 3.0 power bank ?
    thx in advance.
    09-10-2016 09:54 AM
  20. traynor1987's Avatar
    thx in advance.
    Yes it does. It'd backwards compatible with quick charge 2.0. I have an anker one myself
    09-10-2016 10:00 AM
  21. NotAnAppleGuy's Avatar
    Compared to two weeks ago around this time.
    09-12-2016 09:16 PM
  22. NotAnAppleGuy's Avatar
    And..
    09-12-2016 09:17 PM
  23. Psycho_Bucka's Avatar
    As is mine...
    09-12-2016 09:46 PM
  24. Mooncatt's Avatar
    This is normal to see. For one, the batteries need time to break in before giving you full capacity. Second, you're probably not using it as much as when you first set it up and exploring all the features.
    09-13-2016 03:30 PM
  25. Lobwedgephil's Avatar
    Hope 60% works for us soon.
    09-13-2016 06:39 PM
601 ... 22232425
  1. Honor 5C: Too similar to the Honor 5X?
    By lumivalo in forum Honor 5C
    Last Post: 01-27-2017, 01:05 AM
  2. Replies: 10
    Last Post: 08-26-2016, 06:14 PM
  3. Sprint Note 5 unlocking
    By James Hogg in forum Sprint
    Last Post: 08-23-2016, 07:46 PM
  4. Replies: 0
    Last Post: 08-21-2016, 09:06 PM
  5. Replies: 0
    Last Post: 08-21-2016, 09:00 PM
