09-13-2016 05:44 PM
601 ... 34567 ...
tools
  1. qnet's Avatar
    I'm not getting much more than 3 hours on mine before plug in at night but I'm using all of the bells and whistles plus staying connected to an Android Wear watch all day
    That's about what I get, which is good enough for me. I keep all my stuff turned on also, and have several things connected and syncing. I keep my screen brightness pretty high also.
    08-21-2016 09:13 AM
  2. seafoodlover88's Avatar
    I thought I was smart when I purchase my S7E international unlock version. When I realize it didn't support T-Mobile 4G LTE band, I return it and kind of felt like a fool. I should have done my research....BUT the battery life on the Exynos 8890 should be applauded. It had Insane battery life. I was playing Star Wars: Galaxy of Heroes and for anyone who don't know it a pretty graphic intensive games made by EA games and after 1.5 hours, I only went down by 20% battery at max brightness and sound. Similar user have noted that you get an exact 22% more than the Snapdragon variant that is limited to the U.S and China. I could go a day and a half on the Exynos processor and what even more surprisingly is compare to my Note 3, I could play games at 1% while charging without it ever shutting off. The Exynos also ran cooler so it never overheat. I was getting 11 hours and 45 minutes off on screen time watching Youtube which is a little more than 2 and a half hours longer than the SD processor.
    I never compare the battery life to my dad Iphone 6s plus so I don't know how it compare to Iphone battery life but if only it supported U.S 4G LTE band, I would never have return it. With that said, I recently got my hand on my friend U.S Note 7 and not impress at all. Battery life seem to be at 4.5 hours off on screen time which is a far cry from what I experience. Regardless this doesn't just apply to the U.S Note 7 but all U.S phones in general. I don't expect any phone without a SD 821 to complete and even still I don't know if the SD 821 will even complete against the 8890 made by Samsung.
    So tell me, do you guys think I'm spoil by amazing battery life? 3600 mah isn't the greatest but the 8890 processor is able to squeeze out more battery life than just 3600mah. I was getting close to 900 plus more mah which is close to a 4500 mah battery if my math is correct.
    08-21-2016 09:14 AM
  3. alejovh1#AC's Avatar
    Yeah. Lots of post about battery life. In general the battery life seems just average. I get consistently 4 hours of sot.
    I was hoping for 5 or more, been able to get 6 hours plus on the oneplus 3 and iPhone 6s plus. The battery life is a deal breaker for me but on the plus side, this note is just the most beautiful and functional note to date.
    It's just damn sexy!
    duke1231 likes this.
    08-21-2016 09:21 AM
  4. Zack Fawley's Avatar
    There are tradeoffs between exynos and snapdragon. The exynos is just a better CPU, it's certainly more power efficient and faster....but the snapdragon is no slouch, and is paired with a far superior GPU. I have no doubt you were probably getting better battery life on the exynos, but you'll get better gaming performance now out of the snapdragon. Hope that helps.
    Golfdriver97, geekaren and mru007 like this.
    08-21-2016 09:22 AM
  5. Golfdriver97's Avatar
    The thing about battery life to consider is this: Everyone has a different set up. Different things going on in the background from different apps, different cell signal strengths, etc. Another thing to consider is the extra processes for the pen on the Note. So this kind of thing is hard to measure. It wouldn't surprise me if the Exynos is a bit better at battery life than the SD. As for your point of view on battery life....I have always looked at battery life on phones this way: Can I get through my day with normal use and still have a cushion of life left? If the answer is yes, I don't sweat it. If I have to get to a charger long before I normally do, then and only then, do I become concerned with the battery.
    08-21-2016 09:24 AM
  6. zmann's Avatar
    Picked my 7 up yesterday and I'm loving the battery.. My normal routine this morning is to take phone off the charger at 6:45 and go to the gym. I just got back and my note 5 usually at 80 percent but the note 7 with same exact use is at 91 percent so no complaints here.
    08-21-2016 09:28 AM
  7. shook187's Avatar
    This is totally not the way to explain it. You don't magically get extra milliamps between the two chipset. The better way to explain it is, the Samsung Exynos chip runs cooler so you get less battery drain then the Snapdragon chipset.
    08-21-2016 09:33 AM
  8. D13H4RD2L1V3's Avatar
    On my usage pattern, I tend to get around 5-6 hours of screen-on time with around 13-15 hours of total uptime. If your usage pattern is lighter, you may get more runtime out of it.
    Battery life depends on multiple factors, such as efficiency of the hardware, software optimization, cellular signal strength, along with an individual's usage pattern.
    However, I've been pretty happy with the battery life I'm getting out of my Note7. Lasts me a day without issue.
    If you're asking, my unit is an SM-N930F unlocked variant, running on an Exynos 8890.
    mru007 likes this.
    08-21-2016 09:37 AM
  9. anon(5630457)'s Avatar
    I never got more than 3.5 hours SOT on my S7 edge (SD 820 variant). I'll probably get about that on my Note 7. I did yesterday. No big deal. SOT is but only one variable for battery life/quality.
    08-21-2016 09:38 AM
  10. thegame161's Avatar
    Everybody will get different kind of usage as we use our phones in different ways.
    As long as it lasts all day I don't see the big issue not with fast charging available.
    08-21-2016 09:41 AM
  11. boufa's Avatar
    For the record... you should not be looking too close at battery life for about a week after purchasing a new device. The battery and your usage patterns need to settle into a groove. This is very common. I had 7 hours of SOT yesterday. However I am not jumping for joy. 1) It was new, and I will likely never have 7 hours of SOT again... I mean I will not have the screen on for 7 hours in a single day again. also 2) I had not loaded many apps, at least most of them were not on the whole day. So there might be a battery hog (I'm looking at you Facebook app and Weatherbug!) that I loaded in that will kill my battery. In addition, the actual chemistry of the battery has not reached peak efficiency... takes several full charge discharge cycles for that to happen.
    08-21-2016 09:51 AM
  12. Jtshurtleff's Avatar
    This is where I am at right now so I'm not complaining. If I get 3 hours SOT but am at 15% after 14 hours then I am fine with it. I listen to audio books through Bluetooth at work and text via MightyText from my computer a good bit so that tends to drain the battery a bit. On weekends I get more like 4 hours over 2 days or at least I did on my S7E.
    08-21-2016 10:12 AM
  13. seafoodlover88's Avatar
    I heard something about that but when you mention game performance, are you talking about loading speed cause the Exynos 8890 loading speed is still faster. Unless you are talking about GPU, and if so is it a difference I would actually notice? I wish I had an SD variant as well so I could get a clearer picture.
    08-21-2016 10:44 AM
  14. RichBrown68's Avatar
    For those who are insinuating that people with good battery life are somehow lying or faking their results, I would point out that in android central's review, they state that battery life is one of the pros of this device, and on the YouTube channel, Ask the Android Guy,(otherwise known a R-I-C-K-Y the Android Guy), he States that he is getting better battery life on the Note 7 than on the S7 edge. More importantly, to me anyway, I also am getting better battery life.
    --RICH
    08-21-2016 11:48 AM
  15. ThrottleJohnny's Avatar
    The first week if having a new phone isn't really a good time to gage battery life, as most people are playing, adjusting, downloading and syncing non stop.
    Give it a few weeks until your routing settles into normalcy.
    08-21-2016 11:59 AM
  16. Nakrohtap's Avatar
    Honestly, without going out of my way to not plug my phone in all day, I don't think I'll ever know how much SOT I can get in one full charge. During the day, if I ever see it below 70%, I will usually plug it in.
    08-21-2016 12:07 PM
  17. pre1561's Avatar
    I'm a long time Samsung user, I have the Note 4 now. I can upgrade in October. The Note 7 sounds great, however I have had my Note 4 for 2 years now and I have had to replace the battery twice. What's going to happen when the Note 7 battery has to be replaced? The repair shop where I live has told me they can't change the battery and it would have to be sent back to the factory. Of course the user would loose there phone for a while and probably a long while. There are no loner phones either. I'm also considering an LG phone I think the G5. I'm also thinking I could buy a prepaid if I had to. Am I worrying about something I shouldn't be worried about? Thanks for any advise.
    08-21-2016 03:38 PM
  18. Connert's Avatar
    I've spent the last several days tweaking my Note 7 to the way I like and use my device for me to be efficient. I set the screen to auto and put the slider just about 50%. After playing around on AC forum, music for 45 minutes at the gym and a few text I checked SOT and was very surprised at the results. The only thing I really did to help with battery was turn off "ok google". The Note 7 Battery life Thread-1471812926813.jpgThe Note 7 Battery life Thread-1471812936281.jpg
    08-21-2016 03:55 PM
  19. dsignori's Avatar
    I really don't know why any battery metrics matter to anyone honestly. They are just numbers.
    • Seriously, if you can unplug your phone in the morning, do what you want to do on it all day, and it's not dead at night when you plug it back in to charge, why do ANY of the numbers matter?
    • In addition, if you are like me, and have the opportunity to charge your phone during the day at work or in the car, then do it and don't worry about it. I realize some folks don't have this option. If you don't have that option, then see above.
    08-21-2016 04:57 PM
  20. erasat's Avatar
    I wasn't even going to post on this or any other battery threads anymore as it seems that people still find the need to critic people that do their stuff to just get the best out of the phone's battery life, and it simply gets tiresome.
    But, some of you are complaining that are getting less battery life than an iPhone with a 4.7" and 720p screen and about 523 maximum nits or the other iPhone with a 5.5" and 1080p screen with about 563 maximum nits. Ehhh, sorry but you bought a phone with a Quad HD 5.7" screen and over 1000 maximum nits, so yes, having the phone at maximum screen brightness will hurt battery life more than anything else and a lot if not all of other phones out there.
    I'm not going to say that you shouldn't use it the way you want, just that if you do, then you need to take everything in consideration because you are not comparing apples to apples here.
    Do yourself a favor and see all the hints of people used to Samsung phones and their screens and services and work around 50% of brightness, turn off Google Location Services, disable or Uninstall all the phone bloatware and turn off sync for unused Google Account services and you will see the huge difference in your battery life, and will see that you are not crippling the phone just getting the best out of it. None of the above are iPhones issues simply because they don't have them, plus they basically converts the phone in a dumb phone once you turn that screen off, totally opposite to android's approach in which everything is on by default.
    Don't fool yourself, this phones need some managing on the initial setup and the Quick toggles are there for something remember, you can also leave all your house's lights on all the time but what do you really do? Get the point?
    Listen, I'm not here to begin a discussion about this, for me this is pure deja vu, you do what you want to do, just try to understand that people with great battery life are not liars or Samsung fan boys, they are just savvy owners getting the most out of their phones resources.
    Connert, blessedred and Jdroids like this.
    08-21-2016 05:01 PM
  21. jjj651's Avatar
    Battery life is definitely not as good as and iPhone 6 Plus but I've just decided to just live with it.
    08-21-2016 05:10 PM
  22. 1901Madison's Avatar
    What was your battery life like on the iPhone 6 Plus? I went from the 6s Plus to a Moto Z Force and the Force gets far better battery life than the 6s Plus. I would have thought the Note 7 would get similar battery life to the Z Force since they both have 3500mah batteries.
    08-21-2016 05:15 PM
  23. RadeonHD4250's Avatar
    I know this is a Note 7 forum, but I feel posting this here might conjure up interesting discussion.
    Mind you, the screenshot is a Note 4 that has a smaller (older battery), an a less efficient SoC and operating system.
    I browsed the Android Central app and got over an hour of SoT and only used 10%. If I were to continue to browse in that same amount of time, I'd easily hit 11-12 hours of SoT. But this isn't "normal" use to me. Everyone can easily hit 8 hours SoT if all they did was browse a forum on it.
    Obviously those who have higher SoT use their phones with the screen on for longer "sessions" ie watching a movie, browsing a forum, reading an ebook, etc.
    If you're actively turning the screen off and on (answering a text or message) or have a high STANDBY time, obviously you'll get less SoT, but MORE Standby, which is the more important factor to me.
    I average 4-5 hours SoT with 48-72 hours of standby on average with my Note 4. The day someone shows me a screenshot of 7-8 hours of SoT with more than 48 hours uptime, THEN I'd be impressed. But so far, most who hit that magical number are not getting a full 24 hours of use from it.
    Just use your phone and be happy. I don't have the Note 7 yet, so just be happy you own it!
    08-21-2016 05:16 PM
  24. ThrottleJohnny's Avatar
    Thanks you!
    08-21-2016 05:26 PM
  25. Nakrohtap's Avatar
    I've spent the last several days tweaking my Note 7 to the way I like and use my device for me to be efficient. I set the screen to auto and put the slider just about 50%. After playing around on AC forum, music for 45 minutes at the gym and a few text I checked SOT and was very surprised at the results. The only thing I really did to help with battery was turn off "ok google". Click image for larger version.
ID:	236518Click image for larger version.
    6 hours 42 minutes SOT with 9 hours off the charger is not typical. Typically, unless you are doing something out of the ordinary, you want your phone to last all day. That screen time is great. But, don't expect to get 16 hours off the charger and almost 7 hours SOT. Some people are comparing against other people and should just be comparing their stats to their previous phone.
    08-21-2016 05:27 PM
601 ... 34567 ...
  1. Honor 5C: Too similar to the Honor 5X?
    By lumivalo in forum Honor 5C
    Last Post: 01-27-2017, 12:05 AM
  2. Replies: 10
    Last Post: 08-26-2016, 05:14 PM
  3. Sprint Note 5 unlocking
    By James Hogg in forum Sprint
    Last Post: 08-23-2016, 06:46 PM
  4. Replies: 0
    Last Post: 08-21-2016, 08:06 PM
  5. Replies: 0
    Last Post: 08-21-2016, 08:00 PM
