I wasn't even going to post on this or any other battery threads anymore as it seems that people still find the need to critic people that do their stuff to just get the best out of the phone's battery life, and it simply gets tiresome.
But, some of you are complaining that are getting less battery life than an iPhone with a 4.7" and 720p screen and about 523 maximum nits or the other iPhone with a 5.5" and 1080p screen with about 563 maximum nits. Ehhh, sorry but you bought a phone with a Quad HD 5.7" screen and over 1000 maximum nits, so yes, having the phone at maximum screen brightness will hurt battery life more than anything else and a lot if not all of other phones out there.
I'm not going to say that you shouldn't use it the way you want, just that if you do, then you need to take everything in consideration because you are not comparing apples to apples here.
Do yourself a favor and see all the hints of people used to Samsung phones and their screens and services and work around 50% of brightness, turn off Google Location Services, disable or Uninstall all the phone bloatware and turn off sync for unused Google Account services and you will see the huge difference in your battery life, and will see that you are not crippling the phone just getting the best out of it. None of the above are iPhones issues simply because they don't have them, plus they basically converts the phone in a dumb phone once you turn that screen off, totally opposite to android's approach in which everything is on by default.
Don't fool yourself, this phones need some managing on the initial setup and the Quick toggles are there for something remember, you can also leave all your house's lights on all the time but what do you really do? Get the point?
Listen, I'm not here to begin a discussion about this, for me this is pure deja vu, you do what you want to do, just try to understand that people with great battery life are not liars or Samsung fan boys, they are just savvy owners getting the most out of their phones resources.
