Let's make a summary here.
Tell us, have you disabled Bloatware, all or just a few? You mentioned Location will be off, but did you disable Wifi and Bluetooth Scanning and Google Location service on location? What are your brightness settings? How good is your signal? Have you activated and change to Always the App Power Saving features in Battery-App power Savings-Detail? I think you mentioned that you have a dual sim device,do you have both activated at the same time? If so, have you tried using just one at a time to see if one of them is causing the issue? Can you post today's Battery stats screenshots, as much details as possible?
All the above questions are very important to know trying to find what may be causing your issue, if everything above is as expected or you have already worked on it, then you must have a rogue app, trying to see your battery stats can help.
Ok I'll give as much details as possible.
1. I used package disabler pro to disable all the bloatware. This means according to them around 95 packages. Noticed an increase in speed but not in battery.
2. I turned off all of the location services you mentioned above yesterday. Hasn't had any positive influence so far either.
3. My signal is pretty great throughout most of the day. Maybe sometimes I drive by somewhere with less signal but it should last more than 5 minutes...
Yes Im using the dual sim version, but I can't turn off one sim because I need both for work every day.
4. Luminosity is set to auto.
5. I haven't turned on any power saving mode cause I want to use my phone as fully as possible since other people manage to do it and have good battery.
6. Turned off all the automatic scanning options like you said!
Today, my results are very consistent with every other day.
Around 10 hours on battery and always less than 4 hours of SOT. It's so disappointing. I would love to hit at least 5 hours SOT. Many people here get over 6.
The last option I can think about is to reset my phone to factory and not use smart switch, but I've read mixed reviews about this. Below screenshot of my battery stats today!
Any ideas what I can do now? Thanks again for caring about my issues!!
