1. N0117859's Avatar
    Just got the new Note 7 and I'm trying to install the Mobile@Work app from MobileIron. The application won't install from the app store. Keep getting error message that states: "Your company has set up a work profile. To continue using Mobile@work, please use the badge version installed on your device." The app won't install at all.
    This is not a work phone. Its a personal phone with no work related stuff or work related profiles on it, so my employer has nothing to do with it. Can anyone help?
    08-21-2016 11:49 AM
  2. gpatrick15's Avatar
    Only reason I'm able to use my Mobile Iron client is because my job authorized it. I'm only able to sign in because my job has it set up for me to sign in. My phone isn't a work phone either but I'm required to have my email and calendar on my phone.
    08-21-2016 02:27 PM
  3. N0117859's Avatar
    But didnt you have to download the app first, and then input the security info to access the company email an calendar? It wont even install the app. I have directions from my employer, but the next steps have to do with opening the app after installed so I can input our company security info. However I cant get to that next step if the Mobile@Work app won't install.
    08-21-2016 05:44 PM
  4. DubyaC's Avatar
    I'm having the exact same problem as N0117859. I'll contact the tech support at my company today and see what they say.
    08-22-2016 06:18 AM
  5. Krahe Vater's Avatar
    Was supporting a user with this issue on this model device.
    User had set device up as a work phone during initial setup.
    User factory reset and chose instead to set as personal phone.
    MobileIron then installed and setup with no further issues.
    Not sure if factory reset is the only way to make this change. Maybe it can be changed somewhere in settings. Let me know if you find it.
    08-22-2016 02:06 PM
  6. d2k1323's Avatar
    During the initial setup process it didn't give me an option to select between personal and work but I was having the same issue. I factory reset my Note 7 and it solved the issue. Seems like something in the initial setup of the Note 7 is preventing the mobileiron app from working properly.
    08-24-2016 04:37 PM
  7. narutoninjakid's Avatar
    Figured out the issue after troubleshooting for a user who had this. If you setup secure folder you will then begin to get these errors. Phones may be prompting you to setup secure folder in the beginning setup or certain carriers may Have work and personal setup. Try disabling secure folder and see if this helps.
    09-01-2016 08:03 AM
  8. neowulf1's Avatar
    Im having the same trouble. Regarding your suggestion. Where does one find "secure folder" and how does one disable. I don't see such folder to disable on my device.
    09-02-2016 05:56 PM
  1. Galaxy Note 7 touch sensitivity... too sensitive.
    By Michelle MacCracken in forum Samsung Galaxy Note 7
    Last Post: 08-30-2016, 07:12 PM
  2. I'm new to Galaxy S6
    By gold20 in forum Samsung Galaxy S6 Accessories
    Last Post: 08-22-2016, 02:13 PM
  3. Samsung OEM Screen Protectors ~ Anyplace to Buy Other than MobilFun?
    By jfenton in forum Samsung Galaxy Note 7 Cases & Accessories
    Last Post: 08-21-2016, 09:29 PM
  4. Samsung Pay not Working on S2 w/ Note 7
    By Jimmy Bernstein in forum Samsung Gear S2
    Last Post: 08-21-2016, 01:26 PM
  5. Facebook on Note 7. WTH?
    By spasell in forum Samsung Galaxy Note 7
    Last Post: 08-21-2016, 11:47 AM
