Is this a good one and Will it work on note 7?
http://www.amazon.com/gp/product/B012AWBN9C?tag=hawk-future-20&ascsubtag=UUacUvbUpU5353417
My TYLT charger that I've been using for my Edge+ works perfectly with the Note 7
I would avoid ebay unless it was from the official best buy, Samsung, or similar large storeI picked up a wireless fast charger OEM off eBay for 27 bucks ...it's the 2016 version that doubles as a stand http://m.ebay.com/itm/152169104084?_mwBanner=1. ....Gotta be careful though because eBay has a lot of fakes.... That charger you linked will work with the note though
I ordered two of these..... you have to order the usb wall adapters separate... they cost $11 and have dual usb ports
//uploads.tapatalk-cdn.com/20160822/4d05bc7a0174b680fc21cd2195600f27.jpg//uploads.tapatalk-cdn.com/20160822/e21d8a5fd812f01f94b1c352aede63f1.jpg
Thanks!!!! I was able to cancel the adapter..... I'll use the wall adapter that came with the phone, with the wireless charger until I make my next Amazon orderThis charger will not work. Wireless fast chargers require a quick charge 2.0 or 3.0 wall adapter. This one you purchased is only a smart IQ charger which only produces 2.4amps and is not Qualcomm quick charge compatible.
Hmmm..... I'm going in target tomorrow and get one.... I'll use the $20 from Samsung pay promo and pay the difference in cash. So it would only cost about $25 or so dollarsTarget has the official samsung fast wirelss charging stand for $42.99. I just ordered mine (with the 5% redcard savings) Not too bad.
Target : Expect More. Pay Less.
No issues with a case on.Does the samsung wireless fast charger have any issues charging with a case on?
