1. nonie's Avatar
    Is this a good one and Will it work on note 7?
    http://www.amazon.com/gp/product/B01...cUvbUpU5353417
    08-21-2016 07:21 PM
  2. Strong_Genetics's Avatar
    I picked up a wireless fast charger OEM off eBay for 27 bucks ...it's the 2016 version that doubles as a stand http://m.ebay.com/itm/152169104084?_mwBanner=1. ....Gotta be careful though because eBay has a lot of fakes.... That charger you linked will work with the note though
    08-21-2016 07:26 PM
  3. nonie's Avatar
    Thanks
    08-21-2016 07:28 PM
  4. wildcard30's Avatar
    Yep it is compatible. This is the one I use
    https://www.amazon.com/Charge-Wirele...cUvbUpU5353436
    nonie likes this.
    08-21-2016 07:28 PM
  5. bhatech's Avatar
    That should work but I use the new one with the stand which is also around $40 - $45 on Amazon. I like the stand because it doubles as a night clock out a desk clock etc.
    nonie likes this.
    08-21-2016 07:29 PM
  6. keepnitreel's Avatar
    I ordered two of these..... you have to order the usb wall adapters separate... they cost $11 and have dual usb ports
    08-21-2016 07:35 PM
  7. Iva_LadyDiCaprio98's Avatar
    That's the one I have and it works pretty good, haven't had an issue and I've had it since the S7 Edge came out
    nonie likes this.
    08-21-2016 07:35 PM
  8. omgitselaine's Avatar
    My TYLT charger that I've been using for my Edge+ works perfectly with the Note 7
    Nygiants1991 likes this.
    08-21-2016 07:55 PM
  9. Nygiants1991's Avatar
    I like that lot. Was it expensive
    08-21-2016 08:11 PM
  10. omgitselaine's Avatar
    I got it for $60 something if my memory serves me correctly but that was from their website.
    Check Amazon since I believe you can find them for less there ?
    08-21-2016 08:13 PM
  11. dpham00's Avatar
    I would avoid ebay unless it was from the official best buy, Samsung, or similar large store
    08-21-2016 08:24 PM
  12. dannyar11's Avatar
    https://uploads.tapatalk-cdn.com/2016...2195600f27.jpghttps://uploads.tapatalk-cdn.com/2016...52aede63f1.jpg
    This charger will not work. Wireless fast chargers require a quick charge 2.0 or 3.0 wall adapter. This one you purchased is only a smart IQ charger which only produces 2.4amps and is not Qualcomm quick charge compatible.
    08-21-2016 08:30 PM
  13. keepnitreel's Avatar
    Thanks!!!! I was able to cancel the adapter..... I'll use the wall adapter that came with the phone, with the wireless charger until I make my next Amazon order
    08-21-2016 08:51 PM
  14. boufa's Avatar
    Target has the official samsung fast wirelss charging stand for $42.99. I just ordered mine (with the 5% redcard savings) Not too bad.
    Target : Expect More. Pay Less.
    08-21-2016 09:47 PM
  15. keepnitreel's Avatar
    Hmmm..... I'm going in target tomorrow and get one.... I'll use the $20 from Samsung pay promo and pay the difference in cash. So it would only cost about $25 or so dollars
    08-21-2016 09:55 PM
  16. trucksmoveamerica#AC's Avatar
    You can get the blue or black for $30 right now for the tylt ones. I have one and love it. It's not fast charging though, I use it by my bed at night so don't need fast charging any way. Works good
    08-21-2016 10:00 PM
  17. ShiftTab's Avatar
    Does the samsung wireless fast charger have any issues charging with a case on?
    08-21-2016 10:09 PM
  18. dsignori's Avatar
    No issues with a case on.
    ShiftTab likes this.
    08-21-2016 10:21 PM
  19. boufa's Avatar
    It shouldn't. However, I got a thicker case that had room for 2 credit cards in the back, and it would not wireless charge for me... (BTW, anyone want a very slightly used credit card Note 7 case!)
    Also, I have seen various chargers listed here. Not all wireless chargers are fast chargers. Also, fast charging is not something that can be trademarked, so anyone can call a charger fast. ie, the Tylt one above, great charger, I have it, is not a true fast charging wireless charger.
    08-21-2016 10:23 PM
  20. archer75's Avatar
    I use the wireless fast charger from samsung. $39.99 from amazon. Works great.
    I'm looking for a good wireless, magnetic, fast charger for the car that will work with a wallet case on.
    08-21-2016 10:26 PM
  21. Strong_Genetics's Avatar
    Yeah eBay can be tricky but this one is oem and made by Samsung and sold by a good seller....There are sooooo many fakes of the fast chargers on ebay though....
    08-22-2016 12:03 AM
  22. ilordvader's Avatar
    I have these
    But the Samsung Wireless charger is best cos of Fast charge
    08-22-2016 02:11 AM
  23. Pippinsky's Avatar
    Was wondering if its okay to use the fast charger as my nightstand charger,or am i better off using the wall wart?
    08-22-2016 09:50 AM
  24. Jaycemiskel's Avatar
    I use a fast wireless charger at night. Haven't had any problems with it so you should be OK.
    08-22-2016 10:10 AM
  1. Wireless Fast Charging issue?
    By Blazeeofglory in forum Samsung Galaxy Note 7
    Last Post: 09-01-2016, 09:45 AM
  2. Will these car chargers Fast Charge the Note 7 using a USB-C to USB-C cable?
    By felloffthetruck in forum Samsung Galaxy Note 7
    Last Post: 08-21-2016, 02:48 PM
  3. Replies: 0
    Last Post: 08-21-2016, 12:24 PM
  4. S7 charger port scratches - return or keep?
    By CladWell in forum Samsung Galaxy S7
    Last Post: 08-21-2016, 09:01 AM
  5. how to make the s5 wireless charging
    Last Post: 08-20-2016, 05:30 PM
