1. ctychick's Avatar
    Is there a way to include both apps and shortcuts in one Edge bar? I only have a few items that I want to include on the Edge, but they are a mix of shortcuts and apps and I don't want to have to swipe over twice when they could all easily fit in one "bar." Hope this makes sense!
    08-21-2016 08:52 PM
  2. boufa's Avatar
    It makes sense. There is an inperfect solution if you want to try it. It will work about 75% of the time.
    Grab from the play store and app called quickshortcut maker. Install it. Use the second tab.. applications.. to select an app, and click create. This will place a shortcut icon to that app on your home screen (don't worry, your not going to leave it there).
    Next go into the edge settings, and use only the TASK EDGE. Chose edit, and then see if the home page shortcut that you just made is listed at the top. If it is, you can add it to the task edge, and you are all set (and you can now delete the home page icon you made in the last step).
    I have found a group of my apps that will not show up in the task edge options. Not sure why. So you have a chance. Not sure if there is any other way. But this might work
    08-21-2016 09:40 PM
  3. robmartin5450's Avatar
    I cannot seem to add Chrome shortcuts to the Internet Edge screen. Can you only add from the stock browser?
    08-25-2016 12:40 AM
  4. coolbreeze78's Avatar
    It's a Samsung feature so I'd imagine they want you to use their browser (for site logs and marketing hits)...
    08-25-2016 12:42 AM
  5. boufa's Avatar
    It's less sinister than that.. though they maybe doing that too.
    Bookmarks are not bookmarks. Each app handles, codes, and stores them differently. So the edge panel is coded for the one that it knows.
    There is a chrome edge panel in the downloads section. Likely cost you $1.50 ish.
    08-25-2016 06:40 AM
  1. Replies: 2
    Last Post: 10-06-2016, 05:43 AM
  2. Sports ticker edge scroll?
    By noordzy77 in forum Samsung Galaxy Note 7
    Last Post: 08-21-2016, 10:51 PM
  3. Replies: 1
    Last Post: 08-21-2016, 03:39 PM
  4. Best screen protector for Samsung Galaxy S7 Edge?
    Last Post: 08-21-2016, 03:24 PM
  5. edge colors during a call
    By wcupk in forum Samsung Galaxy Note 7
    Last Post: 08-21-2016, 02:40 PM
