1. smooth4lyfe's Avatar
    I heard a lot of people saying its not useful, but I find it pretty awesome!
    I absolutely love Edge lighting, I think its a pretty cool feature
    And I do love the edge panel mostly for sports scores and to check my stocks which I use
    Anyone else find the edge screen useful?
    cinnamin, Herwick and Thisistip like this.
    08-21-2016 11:30 PM
  2. eyecon82's Avatar
    I hate it
    08-22-2016 12:03 AM
  3. Carlo Villa's Avatar
    I love it
    Gsxr151 likes this.
    08-22-2016 12:21 AM
  4. Makad's Avatar
    Take or leave, even though i use it
    08-22-2016 12:55 AM
  5. Almeuit's Avatar
    I'm enjoying it. It's way less than the S7 edge.
    08-22-2016 01:19 AM
  6. dpham00's Avatar
    Curve is ok. But edge screen features are pretty useless for me
    08-22-2016 11:41 AM
  7. jshah500's Avatar
    I have the edge screen feature set up, but don't see myself using it much. Probably just need to get used to the fact that it's there.
    08-22-2016 12:10 PM
  8. Vivaxha's Avatar
    Do you find Note 7 better for your hand than the S7 Edge?
    08-22-2016 12:12 PM
  9. Jona005's Avatar
    I like it a lot.
    08-22-2016 12:13 PM
  10. James Pettengill's Avatar
    I'm a fan of the edges. That was the whole reason I chose the S6edge+ last year over the note (always been a note user) I wanted the curved edges and something that was different. I wish they would have stuck with the same edge profile as the edge+ tho. These edges on the note are okay but basically useless as an edge display. Most everything is just on the edge of the screen. At least on the edge+ the actual edge was readable from well, the edge when looking at it from the side. But this is still a great blend of the two devices, note and edge+.
    Thisistip likes this.
    08-22-2016 12:18 PM
  11. Nakrohtap's Avatar
    For a normal screen, it's fine. For edge purposes, especially the night edge clock, not so useful.
    So, if you are really wanting a phone to take full advantage of the edge features, get the S7 Edge, not the Note7.
    08-22-2016 12:19 PM
  12. Thisistip's Avatar
    I love it but I'm a previous a note Edge users. I actually want more of an edge
    Gsxr151 likes this.
    08-22-2016 02:47 PM
  13. Thisistip's Avatar
    You can disable it if you like.
    08-22-2016 02:48 PM
  14. smooth4lyfe's Avatar
    Really? How so?
    I thought it was the exact same
    08-22-2016 03:33 PM
  15. smooth4lyfe's Avatar
    What's the difference between the S7 Edge and Note 7 edge screen? I thought it was the same
    08-22-2016 03:34 PM
  16. Almeuit's Avatar
    Really? How so?
    It is way less edge. It is more subtle than in your face.
    smooth4lyfe likes this.
    08-22-2016 03:38 PM
  1. Customizing Edge content?
    By ctychick in forum Samsung Galaxy Note 7
    Last Post: 08-25-2016, 07:40 AM
  2. For those with a hue over their screen.... I have a solution
    By rxghost115 in forum Samsung Galaxy Note 7
    Last Post: 08-24-2016, 12:09 AM
  3. Unlocked Galaxy S7 Edge Stuck on HSPA
    Last Post: 08-21-2016, 10:42 PM
  4. All of a sudden cant send text messages to certain contacts
    Last Post: 08-21-2016, 10:19 PM
  5. Just ordered the Sony Experia X, taking the XA back. Advice.
    By Dconn1975 in forum Sony Xperia X & X Compact
    Last Post: 08-21-2016, 09:59 PM
