1. The Big Biff's Avatar
    I am using the Always on Display feature. I took out my Pen, created a note on the lock screen, then hit the "pin" icon, so it was then saved to my Samsung notes. I went into Samsung notes, and hit the option, "pin to home screen". Now, after I did this, and locked my phone, my Always on display shows a little "pin" icon. I cannot get rid of this icon now. I deleted all my notes from the home screen, and even from the notes app itself. Yet still, the little "pin" icon remains? How do I get rid of this icon?
    08-22-2016 04:20 AM
  2. Stealthieone's Avatar
    I absolutely had to respond to this one, since I posted the exact opposite.
    To get rid of the little pin on the lock screen you have to turn off the always on display. the pin should only display when you take the pen out.
    Do you have a pin even if the pen is in the phone?
    08-22-2016 04:26 AM
  3. The Big Biff's Avatar
    1. I want to keep the Always on Display on, but I don't want that stupid pin symbol there.
    2. Yes, there is a pin when the pen is away or out.
    I've also turned the display on and off, deleted all my notes, and made new ones, the pin symbol is still there.
    08-22-2016 04:39 AM
  4. Stealthieone's Avatar
    Its supposed to be there if the pen is out...
    You shouldn't see it if the pen is in
    08-22-2016 06:52 AM
  5. shaw1234's Avatar
    While looking at AOD, double tap the pin, double tap garbage can
    08-22-2016 07:44 AM
  1. Really I need Help
    By albaadiankit in forum Ask a Question
    Last Post: 10-12-2016, 10:00 AM
  2. why does screen turn on and stay on while plugged in?
    By all_bran in forum Samsung Galaxy S7
    Last Post: 08-22-2016, 03:31 PM
  3. Replies: 1
    Last Post: 08-22-2016, 03:33 AM
  4. How do I change back to my normal keyboard on Galaxy S4
    Last Post: 08-22-2016, 03:30 AM
  5. Replies: 0
    Last Post: 08-22-2016, 12:15 AM
