1. SoundofReason's Avatar
    i was just wondering for those that have gotten this device, how does it look when watching a show or movie on it?
    I checked out one in Best Buy just to see how it was, and I could see the glare of the light come down on the curve of the phone and that was kinda annoying. When I covered up the top of the phone in landscape mode, the glare went away and honestly, it almost looked flat.
    Sometimes I also like to put my phone flat on a table and watch it that way, have any of you noticed a difference when you do it that way as opposed to a flat screen?
    08-22-2016 12:36 PM
  2. SpookDroid's Avatar
    You can see a slight curve when viewing from an angle (it is definitely not noticeable when looking directly into the screen) and for some reason, the black version has VERY noticeable glare on the curved glass, but is not as bright on the blue or silver version (haven't seen a gold one). With the brightness on an appropriate setting, however, the glare shouldn't be an issue.
    But if glare is bothering you, you can get a matte screen protector (just be aware that that will limit your viewing angles and definitely mute the colors/brightness a bit).
    SoundofReason likes this.
    08-22-2016 12:40 PM
  3. SoundofReason's Avatar
    Oh wow, i didn't even realize that, I will check out best buy when I go home and see if there is a difference, but i think it might be the lighting too because best buy has a lot of lights.
    08-22-2016 02:39 PM
  4. Almeuit's Avatar
    So far so good for me. I watched media on my S7 Edge and now my Note 7 without issue.
    08-22-2016 02:41 PM
  5. SoundofReason's Avatar
    the curve doesn't bother you ? o r you don't see a glare?
    08-22-2016 02:44 PM
  6. Almeuit's Avatar
    The only glare is mainly from glass. I just position the phone where the lights above at work won't glare on the screen (had to do this with all phones really). Once that light isn't right over I just watch and am good .
    08-22-2016 02:48 PM
  1. Galaxy s7 edge keeps going into android recovery!
    Last Post: 08-22-2016, 03:24 PM
  2. Moblie Data While on Phone Call
    By noisemaker in forum Samsung Galaxy Note 7
    Last Post: 08-22-2016, 11:58 AM
  3. Why are there green lines flashing all over my S7 Edge?
    Last Post: 08-22-2016, 11:47 AM
  4. why is my phone S7 Edge freezing?
    Last Post: 08-22-2016, 10:57 AM
