If you use the method in the op then you need to use Nova launcher to access the s cloud activity, since it was made using a Nova launcher widget.So the icon only stays on the home screen in Nova? Once I go back to TW, the Samsung Cloud is gone?
You can also use quick shortcut maker, just search for "cloud"
You can install it from here
https://forums.androidcentral.com/e....sika524.android.quickshortcut&token=_RQZlonU
