1. steveh552's Avatar
    I am coming from an iPhone and Apple watch so I am sorry if this seems like a newbie question but here goes.
    I picked up a Gear 2 Classic today at T-Mobile. Its activated with a data line and all of that. So I was under impression that in the event my Note 7 was not turned on or near the watch, the watch would revert to the data line and at the very least my text would come to my watch. I purposely left my phone home while I ran to the store and when I came home I had several text. They did not come to the watch until after it was reconnected via bluetooth. In addition I had a couple of missed calls that never came through.
    Did some testing and put the phone on airplane mode and would send messages to my phone with Google Voice and they would not go to the watch unless I had the watch connected to the phone with bluetooth. I also had sent to the watches direct number and everything worked perfectly.
    On the Samsung Gear app on my phone I have the forwarding turned on, they did that at the store when activating.
    Any advice or are my expectations to much?
    08-22-2016 03:07 PM
  2. Jude526's Avatar
    Are you on a data plan with your watch?. I have the GearS2 sport and its a standalone watch. I can use it with my phone and without..thats why I chose it. I used the Gear2 which was Bluetooth only. It gave me the smart watch bite. If your watch has its own number it should be a standalone. I can forward my phone to it. The number on the watch is for that
    08-22-2016 10:01 PM
  3. steveh552's Avatar
    Yes it has its own number. I have finally been able to get the calls to forward to it, but not messages.
    08-23-2016 06:06 AM
  4. iDrummer3's Avatar
    You have to go to settings-connections-numbersync. Select connect and follow the prompts
    08-23-2016 06:28 AM
  5. steveh552's Avatar
    Neither the phone nor watch have those options. In the Note 7 I assume your referring to inside the Gear app. I have the call forwarding set up, but its not doing it for texting as well. I spent hours testing and trying to figure it out yesterday.
    08-23-2016 06:31 AM
  6. iDrummer3's Avatar
    On the watch under settings.
    08-23-2016 06:33 AM
  7. steveh552's Avatar
    On that screen I have:
    Bluetooth
    Mobile Networks
    wifi
    NFC
    Alerts
    Airplane Mode
    Data Usage
    Location
    Thats it. When I click each one, not have the option of forwarding
    08-23-2016 06:36 AM
  8. iDrummer3's Avatar
    Under settings I have ATT Number sync. Iim guessing you are not with ATT
    08-23-2016 06:44 AM
  9. steveh552's Avatar
    No, i am with tmobile
    08-23-2016 06:45 AM
  10. daddyd302's Avatar
    He has T-Mobile. Numbersync is a AT&T thingy. :P
    steveh552 likes this.
    08-23-2016 06:46 AM
  11. iDrummer3's Avatar
    I'm not sure then. I just followwed the prompts and it setup by itself.
    08-23-2016 06:46 AM
  12. iDrummer3's Avatar
    Yeah I forgot to ask if he was on ATT to begin with.
    08-23-2016 06:47 AM
  13. steveh552's Avatar
    Thanks for trying to help. I do appreciate it. I may go to tmobile today and see if they can help
    08-23-2016 06:47 AM
  14. daddyd302's Avatar
    I think you can only get call forwarded to your watch. The watch has it's on number for a reason. I'm not sure you can forward text from your phone to your watch. You may have to have people text your watch if you want text.
    08-23-2016 06:50 AM
  15. steveh552's Avatar
    I see. Guess my expectation was different. I did not know att did it different and that is who my friend has.
    08-23-2016 07:01 AM
  1. I think I found Samsung Cloud on the Verizon Note 7
    By vmmatty in forum Samsung Galaxy Note 7
    Last Post: 11-03-2016, 11:50 PM
  2. Does Galaxy note 7 come in different colors?
    Last Post: 08-22-2016, 03:18 PM
  3. Note 7 and Airwatch
    By SteelGator in forum Samsung Galaxy Note 7
    Last Post: 08-22-2016, 02:49 PM
  4. Bluetooth oddity - New Note 7
    By slackerjack in forum Samsung Galaxy Note 7
    Last Post: 08-22-2016, 02:42 PM
  5. Can you adjust the quick camera settings with the S View Cover for the Galaxy Note 7?
    By Zach Glazer in forum Samsung Galaxy Note 7 Cases & Accessories
    Last Post: 08-22-2016, 02:30 PM
