1. miyanc's Avatar
    Ok so I have had a samsung s5 and then the lg g4 and now the note 7. I am not sure if this is a setting issue, am I missing something or is there an issue with the phone.
    Under settings/ battery/ battery usage.
    It says android system 100%. Now und e app power manager is has some info listed but not a full brake down into the 100%.
    I have tried shutting the phone down and charging it all the way up. I have been mostly impressed with the battery life for what I do, at least compared to my s5 and lg g4. But I want to be able to track usage to shut off things I don't want. Am I missing something?
    08-22-2016 08:35 PM
  2. dpham00's Avatar
    Can you post a screen shot?
    Also I would suggest using gsam for more detailed stats
    08-22-2016 08:41 PM
  3. miyanc's Avatar
    I have used gsam in the past. Especially with my lgg4. I am just trying to see what's up with this.
    08-22-2016 08:53 PM
  4. miyanc's Avatar
    08-22-2016 08:58 PM
  5. miyanc's Avatar
    should i post this in a marshmellow thread or android directly?
    08-23-2016 06:39 AM
  6. miyanc's Avatar
    I am not thinking its fixed but it now shows something. I will post screen shot in a sec. I still don't think its acting right. btw I downloaded gsam so I can see more, but still wondering why the samsung/google version is not showing all.
    08-23-2016 07:20 AM
  7. miyanc's Avatar
    08-23-2016 07:22 AM
  8. miyanc's Avatar
    Battery usage.-screenshot_20160823-144923.jpgBattery usage.-screenshot_20160823-145320.jpgClick image for larger version.
    So not fixed. This is a half day of use.
    08-23-2016 01:52 PM
  9. dpham00's Avatar
    Looks like some bug in the system. But your battery like looks fine.
    08-23-2016 02:54 PM
  10. miyanc's Avatar
    Yes and although I can use gsam, the stock should get me something. Other then a hard reset, any suggestions on fixing or who to report it to?
    08-23-2016 03:03 PM
  11. Zaku77's Avatar
    I'm at 67% right now, and my previous phone (Moto X Pure) would be at about the same by this time of day, but that would be after having charged it back up to full already.
    08-23-2016 04:56 PM
  12. miyanc's Avatar
    Ty for ur input
    08-23-2016 05:35 PM
  13. miyanc's Avatar
    I have little issue with production. I also don't feel left out with having gsam. But also would like to have a $36 a month top of the line product not functioning correctly. I also think a factory reset may fix it. Not something I want to do but also don't want to wait longer to do it if it's needed.
    Is there a complete restore. Like if I used a ghost drive for a pc. So I don't have to redo Everything?
    08-23-2016 05:38 PM
  14. TheLegoJoker's Avatar
    Oops. Didn't see main thread.
    08-23-2016 07:40 PM
  15. miyanc's Avatar
    Gonna do the factory reset. Hate to have set up my phone again. What a pain. This battery thing will drive me nuts. So back to factory.
    08-23-2016 08:57 PM
  16. miyanc's Avatar
    Ok so we are now back to normal and I have to AGAIN set my phone up. I understand the complexity of going from say lgg4 to a note 7 but is there a way to ghost or duplicate a phone. So I could just reload the mirror? It takes a long time to redo everything.
    08-24-2016 07:50 AM
  17. Stealthieone's Avatar
    Back up your data... You can use nova to back up your theme/layout of your icons, etc... And then if you reset restore from backup then use nova to get everything looking the way it used to
    08-24-2016 07:56 AM
  18. miyanc's Avatar
    i get that and did back up. layout is the least of my worries. its the apps, logging in, defaults, preferences.
    for example. i lost my samsung pay info. cards entered including my $20 free card. email accounts. disabling bloat,
    08-24-2016 08:51 AM
  1. Wireless charging battery pack
    By alejovh1#AC in forum Samsung Galaxy Note 7 Cases & Accessories
    Last Post: 08-26-2016, 01:43 AM
  2. Lemon ???drain battery and warm note 7
    By Anna320 in forum Samsung Galaxy Note 7
    Last Post: 08-23-2016, 03:17 PM
  3. New battery for s5, phone still dies quickly
    Last Post: 08-22-2016, 07:41 PM
  4. Warranty repair on Battery
    By Tristan944 in forum Moto X Pure Edition
    Last Post: 08-22-2016, 04:00 PM
  5. Replies: 1
    Last Post: 08-22-2016, 03:28 PM
