That's weird. Do you have good signal where you are? If you see the battery consumption report, is there anything that 'stands out' as a big consumer? I'd suggest to factory-reset your phone, especially since it's fairly new and you probably haven't downloaded a lot of things into it.
Mine was off the charger at 6AM and with med/high use (e-mails, facebook, twitter, instagram, more e-mails, a few videos, web browsing, a slew of more e-mails, a couple pictures taken and e-mailed) I'm still at 65% by 3PM, and I don't disable anything (GPS is active, Bluetooth is always on, WiFi is the only thing turned off at the office).
08-23-2016 04:49 PM
