Kelly Kearns
And so then they are posting because? Gloating? Board? Fanatics? Bored?
They are posting because when people have an issue they want to know of others are having the same issue or not.
Perhaps because most folks here understand that Android itself is a systemic issue and then certain apps (ones that do not follow Android framework guidelines) can exacerbate the issues. Android uses a code translation layer, plus has more challenged cache and ram management. There is a main reason why Apple gets away with half the ram on average and that is due to the power of designing for one progressing platform of hardware. That and having only FHD on their phones are huge performance advantages.
Most appear to not be having issues being articulated and attribute any random lag to what they appear to already know. The answers though to mitigate:
1. Did the issues start with a recent app install?
2. Turn animations off in dev settings if using Wiz, Wiz already does it's own. Adds lag if on.
3. Boot into set-up and clean the cache- then reboot. Sometimes installing in a big batch of apps on a new device can cause issues.
4. Return the device
Whatever the case, complaining about it with no apparent effort to fix/understand it does not come across well in forums like this.
I just switched off touch wiz. I did the boot/wipe cache. I done have many apps installed and disables all the carrier and Sammy bloat I could. I lowered animations to .5
I'm now watching battery and wifi use. Killing off notifications that I don't need etc
You "switched off TouchWiz"? How?
Selected nova pro as the launcher
Oh.. Well TouchWiz is still there, you just made Nova your launcher. TouchWiz is more than just a launcher.
is there a full list of system apps to uninstall?
i may have found my battery problem. when i disabled bunch of apps, i didn't change it to system apps option since default option was ALL. I just chose system apps option and there is literally 100 more apps than it is listed under default option of ALL. can someone confirm that i was doing it wrong?
Oh. Crud
The 200 apps are probably your issue in my opinion.I have about 200 apps. But my MXPE runs smoother than this. Screw TouchWiz
I'm curious why there are no Youtube videos posted showing the Note7 lag? I don't doubt that there are those with irritating lag. But I have yet to see a video that shows it. I've seen reviewers mention lag (including Flossy), but have yet to observe it in the review video.
I am shopping for a new phone and am willing to take my time to become educated before I plunk down the cash.
The thing that most concerns me about the Note7 has nothing to do with lag and everything to do with the edge display. I want to use a screen protector (it doesn't have to be glass) and a case like the Spigen or Speck. I don't want a screen protector that rolls up on the edges. I haven't seen much success in that area yet.
Also, since Nougat has been released, I wonder how long it will be before the N7 comes with Android 7 pre-installed? But I digress from the subject of lag.
The thing is there should be no comprises for a phone so expensive.
What are the compromises on the Note 7?
Oh. Crud
