Settings about device tap 7 times on build number, now back to settings you just enabled developer options, open and ajust//uploads.tapatalk-cdn.com/20161003/4e8774609893bac20ecf7b1d2dedc00e.jpg
Turn all 3 sets of animations off.
Then turn the phone off and back on.
Just to make some things clear.
Lag is defined as a noticeable delay between an action or command that is being sent and the expected response that said action should reproduce.
For instance, tapping an app icon but it not doing anything for about a second or two before the app-open animation plays is defined as lag. However, if you tap the app icon but the animation takes a while, that's not actually "lag" in that definition. It just means that the animation is just too long. Likewise, if the phone responds to the action of tapping the app icon with the animation quickly but the app itself takes a while to load, it's usually because the phone is loading the app from storage to memory and the processor is processing data in order to make the app work. That means if your phone has a weaker processor and a slower memory controller like eMMC that's below 5.0 or even 5.1, you will notice a delay in how long it takes for an app to load. Most flagship Androids of 2016 currently use the much-faster UFS 2.0 storage controller, though it's also worth noting that the iPhone uses an even-faster NVMe-based controller.
People really don't know the difference between lag and longer animations....my tmobile note 7 device so far has been lag free with only slight stutters during app installations which is typical on any Android device...both of my iPad pro's larger and smaller can exhibit stuttering at times and the new animations with ios 10 lag a bit now too....
OK, but check out this video: https://vid.me/8eQX. Notice the 1-2 second lag in sound-feedback--not just for typing, but also for icon-tapping when the keyboard isn't even on screen.Even some review videos demonstrating lags on Note 7 isn't really lag to me.
Black Gold from Samsung themes can be found in settings under themes, payed for that one think it was $2.49 sothing like thatCan you tell me the theme are you running?
Wtf Samsung. It was nice for the first few days but now the lag is unbelievable.
Once again, great hardware. Crappy software. Even typing this message was a PITA
