Note 7 not reading 64 gig SanDisk SD card
buzzy3970
2,640
91
48
Is anyone else having trouble with their note 7 reading their SD card? When I first received the phone it worked no problem, but today I noticed it said no SD interested. I've taken it out and placed it back in and it won't read. Tried it in my note 4 and it reads perfectly. Guess I have to go to the store and get an exchange. Just hope they have some blue ones in Stock as I got the last one in store this past weekend.
anon(5719825)
Retired Moderator
Feb 21, 2013
3,797
Try reformatting the card. If you have a computer, copy anything you don't want to lose to a folder on the computer and then format the card. Copy everything back and I bet the phone will then read the card. I had the same problem with my S7 Edge. The card would be read by my Note 4/Note Edge but not by the S7 Edge. Formatting it worked.
PRGDR
204
Before going for an exchange, try reading/writing another card. If it is a hardware issue, it is very likely that you will see problems. But my guess is that the problem lies where others have already commented, format. Let the device format the card.
Good luck!
anon(5719825)
Retired Moderator
Feb 21, 2013
3,797
Good luck!
Remember though that this phone wasn't seeing his card where it could be seen on another phone.
coolbreeze78
374
If you have a digital camera and SD adapter, put it in the camera and format. Put back in phone and format using the phone. This works every time.
jimd1050
Champion
Dec 14, 2011
3,244
9
38
Strangely enough, I had a 64 GB Samsung Pro card from my Note 4 that I pulled out when I had to trade it in to AT&T when I switched from Verizon last year. I ended up sticking it in the free Samsung Tablet they gave me with my Note 5. It still had pictures and music from the Note 4 that I was able to access with the Tab 8. I plugged it into the Note 7 and there they were, fully available again. Not sure if it was ghe initial format by another Samsung device or what but it worked over three generations of devices!
Nakrohtap
Trusted Member
Nov 16, 2011
3,078
37
Yes, the phone isn't seeing the card so it will need to be formatted in something else that does see the card.
Agreed. Format using exFAT on a PC, then put it back in your phone. As long as it reads, it wouldn't hurt to format it again in the storage management settings.
Tristan Dimzon
Active member
Aug 11, 2016
25
Note 7 brand new. I have an issue with mine as well. I store some of my apps to my SD and my pics aswell, often times my SD card cant be detected by my phone but sometimes it is. randomly and intermettently my apps and pics stored in my SD will go missing then reappear after awhile. I thought it was SD card issue so i put the sd card on my old Note 2 phone and tried it for a day no issues whatsoever, so I thought it was the phone, like a loose slot or tray for the SD. I had the phone exchanged, but I have the same issue again. Bought a new SD, formatted it. stored all my old contents. let us see. I mean why will it work then all of sudden it wont?! frustrating!
Tristan Dimzon
Active member
Aug 11, 2016
25
Hey is it fixed yet? Same issue with you although I already exchanged my phone and bought a new SD card, formatted it and transferred all my old data.
lucharmer
