1. hasasimo's Avatar
    It's just stuck on "Preparing"... I'm going to have to unplug the Note 7 from the S7 Edge because the battery is getting low waiting for it to start transferring. Hopefully that doesn't screw anything up. I'd tap the "cancel" button but it's greyed out. Seemed to have simpler experiences restoring on Lumia devices.
    08-25-2016 12:04 AM
  2. Strong_Genetics's Avatar
    How much are you moving over and how long did you wait....My 33 gig switch from my Note 5 was stuck at preparing 97% for a while before it continued...
    08-25-2016 12:09 AM
  3. hasasimo's Avatar
    Thanks for the response. I'll try to just restart the process. I'm transferring only about 7 to 9 gigs. Almost everything was on my SD card.
    08-25-2016 12:12 AM
  4. cary328is's Avatar
    Had the same issue trying to use the stupid cable/dongle. I went with the wireless option instead and it worked much better.
    08-25-2016 01:12 AM
  5. Strong_Genetics's Avatar
    Yeah i used wifi direct and not the cable....
    08-25-2016 01:17 AM
  1. Another Fake GS3 with 4.1.9? ... maybe not ...
    By AndroidMadd in forum Samsung Galaxy S3
    Last Post: 09-06-2016, 03:03 PM
  2. Not a device problem, but maybe a setting or Carrier problem.
    By glidersgalore in forum Samsung Galaxy Note 7
    Last Post: 08-25-2016, 06:57 PM
  3. Replies: 2
    Last Post: 08-25-2016, 08:57 AM
  4. moto 360 sport and 2015
    By Khalid Brown in forum Moto 360 (2015)
    Last Post: 08-24-2016, 10:28 PM
