1. boriqua2000's Avatar
    Anyone else planning on getting one of zerolemons high capacity battery cases when they launch in September? It'll definitely turn your phone into a brick but man i love the juice.
    BustA Groove likes this.
    08-25-2016 03:53 AM
  2. sweeperdk's Avatar
    Have they stated that it's coming in September? I'm getting excited now!
    08-25-2016 04:51 AM
  3. boriqua2000's Avatar
    Yes they did. I emailed them and asked. They replied that their note 7 battery case will be released sometime in September.
    08-25-2016 04:56 AM
  4. comptechltd's Avatar
    What has your experience been with Zerolemon? I had their extended battery with the S5 but still need a belt clip for my phone. The battery seemed to work great but the belt clip kept breaking. While under their 6 month warranty the replaced it for me but after the warranty was up they wouldn't even sell the clip separately saying I had to buy a new battery. Their clip is kinda chincy plastic. Really left a bad taste in my mouth. I am curious about others experiences.
    08-25-2016 05:48 PM
  5. boriqua2000's Avatar
    I've never used any of the belt clips. I always put the phone in my pocket. I've used their batteries on my note 3 and note edge. they're the best. Most extended batteries lose power after a few months. Zerolemons keep strong. I definitely recommend
    08-25-2016 07:17 PM
  6. Dimas de Leon's Avatar
    What capacity? I just ordered the Samsung on sale for $62, should I return it?
    08-25-2016 11:47 PM
  7. boriqua2000's Avatar
    They haven't said the capacity but im guessing over 7000 mahs
    08-28-2016 10:00 PM
  8. Jaycemiskel's Avatar
    Which means it will be huge!
    08-28-2016 10:27 PM
  9. the block's Avatar
    Will NFC/Samsung Pay/Android Pay still work with the Zerolemon battery, or do you have to give that up in exchange for the battery life?
    08-29-2016 09:01 PM
  10. rushmore's Avatar
    More huge than Boriqua2000's belly??
    08-30-2016 09:00 AM
  1. S7 edge battery drain, please help
    By Hock3y Monk3y29 in forum Samsung Galaxy S7 edge
    Last Post: 05-02-2017, 04:34 AM
  2. Replies: 13
    Last Post: 08-26-2016, 12:12 PM
  3. Replies: 0
    Last Post: 08-24-2016, 11:07 PM
  4. Case-mate Fitted Hard Shell Case
    By waterdownzoo in forum Samsung Galaxy Note 7
    Last Post: 08-24-2016, 07:06 PM
  5. Replies: 6
    Last Post: 08-24-2016, 06:24 PM
